LOOK I really can't be bothered to get into this
If one man want's to argue that a jenvey inlet manifold bolted to a carbon airbox with a throttle body stuck a foot away from the head - is EXACTLY the same as a proper ITB setup with the throttles positioned an inch and a half from the head that's fine
But I don't believe it
It's easy to say only one valve is open at once so you don't need a bigger intake - fair enough
But what about volumetric efficiency? Or pulse wave tuning? Or runner length?
I just don't believe that a carbon airbox designed on CAD to fit inside a clio engine bay with the standard throttle body in a place where the wiring will reach - gives the same advantages of a properly designed set of ITB's that you have to cut half the slam panel out to get the right runner length.
They aren't, at a technical design level, the same solution - and ITB's are clearly a better solution and don't cost any more
For me that's the end of the RS2 argument. I'm not saying they don't make good power, I'm not saying they're not a good idea (because keeping your fly by wire throttle and oem ecu is a lot nicer for most than chopping wiring out their engine bay) - I'm just saying THEY AREN'T THE SAME f**kING THING!
And if I'm wrong - and they are literally the same thing - then why is this thread boasting about a 190bhp on a standard engine, and matt@TDF regularly maps 200+bhp standard engines on ITBs?
