The Lunar Grey Mk1 Hybrid Project
  182/RS2/ Turbo/Mk1
Dont get too obsessed with every little pointless detail on a car that if you are going to start learnign to do trackdays in it might get wrecked anyway, get some use out of it even if its only 90% how you want it.
  Lunar Mk1 & Flamer
So working on my dash some more today
Take dummy dash the f**ked template
Make template of binical
Transfer template onto carbon fibre
Now next step will be attachinh into the dash somthing like this
Obviously not this one…. Its broken lol
  Lunar Mk1 & Flamer
So started smoothing over dash centre today…fiberglass dossnt stick to French plastic. But working so far
Should look good when flocked!
  Lunar Mk1 & Flamer
Bit more progress now!
Splitter on, thanks padlar!
Before
After
Arty farty
Bit more dash work!
OK so set about completing the dash2 mount.
Had to put the binical on the belt sander to make it flat! As its moulded to the clocks.
First of all set about mounting the carbon back to the binical used PVC blocking.
And some m6 coach bolts.
Looks pretty good!
Finally mounted dash2
  Lunar Mk1 & Flamer
FLOL! yeah but im an obsessive compulsive... depressed as ive not driven anything with some power for a while :(
  Lunar Mk1 & Flamer
Removed the Oldloom today
Left the enginebay looking like this
Looks so clean without the wiring!
New radiator and Omex wiring loom for beaniesport to chop up lol
Probably going to sell this as won’t be required with itbs
Got bored and fitted excess carpet to garage, can see box on right full of old wiring for beanie sport
  182/RS2/ Turbo/Mk1
Should be a fun car on bodies :)
Let me know if you need me to source you a quaiffe diff cheaper than retail, that will be the next thing holding it back now.
If you want you can pop over to Dan's on sunday near glasto and drive mine before and after me and him fit the quaiffe just to show you what a difference it makes.
  Lunar Mk1 & Flamer
Yes that’s right, finally I’ve removed the distrubutor cap and ht-leads.
The Omex can take care of this for me so now I need a newer “wasted spark” coil pack. The RS Clio uses one but requires Ht-leads to each spark plug. After some reading up found out the f7r in the megane uses a wasted spark setup. However unlike the RS Clio its coil pack sits directly on top of the cam cover and connects direct to the spark plugs. Meaning no ht-leads to worry about. This does however mean I must run the megane cam cover…this in my opinion looks better so wassn’t bothered.
Found both parts for sale on owners clubs within the hour…£65 later they were on their way.
New cam cover
Wasted spark coil pack.
So got busy with my spanners once again.
Removed the cam cover and old 1910 (year it was introduced to a production car by Cadilac) ignition system & cam cover.
Modified the coil pack with some old panel fasteners….
Found some washers in black the right size….
Old Setup
New setup!
  Lunar Mk1 & Flamer
Its going to look much better when the Jenveys are fitted and i repaint the engine bay...looks a bit odd at the moment.
  Lunar Mk1 & Flamer
Centre console Mould making and prototype
So basically I wassnt happy with not having a center panel in the car. So mocked up some ply panels to fit in its place. (this made the dash SOLID)
From this I turned it into a model to make a mould from
Covered this item in release wax and liquid wax…a release agent.
Then covered in gel coat.
This was left to harden over night
Then covered in resin and talc filler and then fiberglass matting
Left to harden overnight then another layer of the same
Then left to harden overnight again 3 layers later its about this thick.
Then “simply” pop the mould off the model…
Screwdriver and hammer required! Leaves you with this.
Run it through the band saw and trim off the rough edges….leaving excess… And then sand with 320grit and 400grit
Then add back plate and add a few layers of wax and liwuid wax (i did 4 but the more the bettrr) layer of gel coat and leave to go tacky… The layer in some material
Happened to have some carbon laying about… not enough but will do on the prototype
Layered it in as I’ve never used it in mould making… So had enough for first layer… Then used low weight fiberglass as replacement (use this normally)
I’ve done 3 layers of fiberglass on top…
Left for a day between layers.
Then simply demould….again…screwdriver required…more wax next time
Removed back plate
And trimmed fiberglass overlap with very sharp chisel
Then popped out of mould
You can see the carbon weave. But I’ve been inconsistent with my gel coat so I have some milkyness… and a few air bubbles...Will be more vigilant with mk2…
But fairly chuffed if this was flocked or painted you would never know.
an All carbon Mk2 coming soon!....
  Lunar Mk1 & Flamer
Lol i normally make moulds for Decorative stone! So.. using the mould for a fiberglass item was kinda new ground.. still im quite chuffed... its stroing as hell... only weighs 700g and can support my weight.
  BMW E36 328
I've just read this from start to finish, and what a build. Good effort and Lunar Grey is just an amazing colour.
  Lunar Mk1 & Flamer
So had a few mins so thought it was a good idea to combine all my interior bits together for trial fitment.
Pics
Then thought I’d see what they were like in the car.
Passenger side
First gear selected in next set of photos for clearance checking... didnt want to be shifting into 3rd to find my hand hit the panel! (and i forgot to finish my other centre panel which is smoothed over...)
Check out the mirror finish of that panel! lol
Got the Race-Technology Dash2 fitted to the car to see if my modified panel fitted and didnt foul
Overall shot
V chuffed fits as it should and I now feel like I have a more complete interior! Yay!
Just got to make an all carbon mk2 now!
  Lunar Mk1 & Flamer
Waved goodbye to the stock inlet and plenum… the polished days are over!
Time for some performance
Looks so empty and bare! Individual throttle bodies will soon cure that! Yay
  182/RS2/ Turbo/Mk1
Should be a fun little car on bodies, although I think eventually you will grow to hate the lag, but its PERFECT for getting in a few trackdays and learning the car properly, then at a later date maybe still proceed with your audi turbo plans.
  Lunar Mk1 & Flamer
pot kettle black,
he he he :p
Yeh im in two minds about that! May just go Boosted f4r!...Seems like another good option! lol
  182/RS2/ Turbo/Mk1
]Yeh im in two minds about that! May just go Boosted f4r!...Seems like another good option! lol
Depends how hard and how often you are going to use it, and how deep your pockets are.
Its quite dear to do well, and still a fragile gearbox unless you get a VAG box on there or whatever, at which point may as well save some money and do the engine too?
Watch my ph1 turbo vids from bedford though if you want to get corrupted, lol
You really need to pop over for a spin in it sometime mate, next meet or something.
  Lunar Mk1 & Flamer
So chopped the steering cowling up to make it fit better with the mk2 dash!
Seems to of worked out alright!
  Mk1 F4R
cars looking really good, just had a read through the whole thread start to hear good read so far can't wait to see whats next
wish i could find some time to continue on my mk1 f4r track car, someday soon hopefully
  Lunar Mk1 & Flamer
Interesting blend of old and new. Would look good all same colour. Flocked for example.
Yup going to send it all away for flockin' :D Know anybody?
Yeah common Adam! Been ages since ive seen yours!
Sorry for the shite update lads!
