182cup & 172 racecar
				I shall be saying "hello".
In preparation for the Cups rewire and new ECU I'm trying to choose and buy gauges - how difficult is this. Can any one tell me if the VDO or TIM 52mm fuel gauge will work with any sender?
Just going for;
Rev's TIM 80mm ?
Oil temp
Oil pressure
Water temp
Fuel level
Volts
Apart from 80mm TIM gauge for revs looking at 52mm for the rest possibly.
Any other suggestions?
Dash 2 not in budget!!
Your better off with warning lights as well pete. That way you'll have a visual indication as looking at gauges whilst giving it some yee ha in a race situation will never happen. Your focus is obviously elsewhere.
Once you've bought all those gauges plus accessories aren't you going to be approaching dash 2 territory anyway? Maybe not lol.
By the time you add it all up, I bet you could score a secondhand dash for similar money?
True, I also can't remember the last time I looked at my dash when out on track or racing - discounting the last race and failed start saw me looking at my limp mode light, really tempted to not bother at all with anything - but I don't know.
The shift light is in the line of sight so no need to look down at all.
Not quite, can get the 5 gauges (vdo or Tim) for around £140 they come with sensors etc. Dash 2 is £500 +Vat...
Hmmm, difficult decision what to go with really.
Race tech dash 2 or similar you mean?
I got my dash 2 for around 400 quid secondhand IIRC, and that was with oil pressure and temp sensors etc as well. (think I actually paid 600 total but that included the logger as well)
But I guess it comes down to time when it comes to secondhand bargains, if you want it in a hurry its not really an option
At 140 quid all in thats certainly very good value, even if you then replace it with a dash2 or similar at a later date.
If you aren't able to go for a one dash does all then personally I would do what Tony and Jay did originally and ran the standard dash. You don't really need a dash 2 the only real advantage of them over a dash 3 or 4 is it has outputs and inputs for sensors etc. You would also need an interface lead though to get the information from the ECU to the dash.
There were quite a few for sale over winter on pistonheads, eBay, racecars direct etc but just had a look and there is only one left for sale which is a Dash 2 and a datalogger so is £800 lol
I still think for a cheaper/midrange option a universal kitcar/bike dash is the best way. Plenty of info and warning lights available on them and the one I linked you to on ebay even had a fuel gauge if you can be bothered to calibrate it.
All that really matters is a revs and temps
Ours doesn't do ITV4
Digital dash from a Yaris?
Would that not be the same as using the stock std dash?
It'd look cooler!
Why do you need to see fuel guage whist racing? Stick it in the side window next to the filler
IMO
Looking good Pete,
Who's ashes are in the box?
Looking good Pete, what size is the rev counter, same size as others?
It still is on the To-Do list and will be for ages
Still dont think you need all that
Looking good Petepersonally I agree with Jay, no fuel gauge, no oil pressure gauge just run the standard sensor with a light, no volt gauge as you can just run a light to come on if the alternator isn't charging and job done
does your ECU have pit lane speed limiter as I notice no speedo?
Why do you need to see fuel gauge whist racing? Stick it in the side window next to the filler IMO
On form tonight Pete.
