11/2024
That's the current state. I moved the car outside of my friends garage because this is very dirty work and dont want to occupy the garage, because we do our regular maitnance in there.
Since I do this after work, it was easy in the summer, day last very long, it's warm etc, but now when I finish with work, there is like 30 - 40 min max of daylight, it's cold etc, can't do progress like that.
I've decided that I'm gonna try to weld all that pieces that I've matched to fit ( cut it from 5 door megane ) myself, I want to lean how to weld, and this is great oportunity for it.
I am in active search for a garage/space to work on a car, to rent it, but it's very hard here in Rijeka, people dont want to rent to someone who's noisy etc etc, rent fee is high, everthing is really pointless.
Inside of the country, for example Zagreb, the prices are much better, less money for bigger space, also bigger spaces for rent etc..
After the summer I really got sick of this car and working on it every day, I really got fed up of it, so, it's kinda "good" that I cant find a space to work on it, so I can get a motivation for everything.
Bad thing, the car is in the open, covered with a car cover, and water finds a way inside..
Biggest regret, now, is that I didnt look the car as a whole in the 1st place , if I did, and if I decided to keep it, at least I could make a "hanger" for the shell and clean and weld everything much easier, then like this, laying under the car, cleaning, everything falling onto you and so on.. Only the guys that have done this know the struggle.
But hey, not everything is bad, much of the hard work is done, kinda.
In plan is to clean all of the underside, paint it, and then paint the exterior of the car.
I also sourced plastic fenders and bonnet for the car, that's lot of weight saving because the car is factory really heavy, would like to find carbon/fiber rear bonnet as well...
Oh, almost forgot, engine has blowby out of dipstick hole and oil cap, so something is bad with the rings..
Hope you enjoyed reading this, cheers from Croatia
