197/200 Brembo Conversion - Wheel Fitment Guide
  Clio 172, MK5 VW GTi
Hello
Can someone please help me confirm a list of what wheels fit on the Pure Motorsport 197/200 Brembo conversion for the 172/182 ?
Specifically, can someone please comment on if the 16" +38mm Team Dynamics 1.2s will fit or if a spacer is required
So far I have found the following:
16" Speedline Turini +45mm offsets - Requires 10mm Spacer
16" Speedline Cup Turinig +38mm - Fit
16" OZ Ultraleggera +38mm - FIT
Related Posts Regards to Brembo Conversion:
http://www.cliosport.net/threads/how-to-get-a-brand-new-brembo-4-pot-kit-for-under-£600.782877/
http://www.cliosport.net/threads/info-needed-brembos.777872/
EDIT - edited your post - optical
MarcB
  Vw Golf
The PMS brackets are a good bit of kit and very nice.
I have so far had this eon my car with 300mm discs / 197/200/225 Brembos & PMS Brackets
Clio 172 Cup Turini's - No Spacer Needed
Clio Trophy Turini's - Spacer Needed
16" Speedline 2108s - Spacer Needed
16" Prima Racing Alloys - Spacer Needed
17" Twingo 133 Alloys - Spacer Needed
NorthloopCup
May be worthwhile posting what the offsets are on each wheel, and what size spacer is required mate. Obviously the cup turini is et38.5 and the trophy items are et45.
Gus
  182Turbo,DCi90
16" ultraleggeras fit. I have them on mine no worries.
  Ex 182 owner
I dont know for sure but I would suggest theres less room on a standard 182 et45 wheel than there is on a Speedline et45 tropy turini. so yes i would defo say you will need some.
Can somebody with the Team Dynamics also respond ?
Also if you have this setup brake setup up and running please state
- Wheel Type
- Wheel Offset
- If a spacer is required how much
dmacmillan
  Clio Sport 172
Hello All,
Is anyone aware if 16” Advan RG with ET44 would clear the PMS Brembo set-up with an 8mm - 10mm spacer?
Finding suitable lightweight wheels a challenge in NZ.
Cheers,
David
Dave182T
  RB Clio 182 turbo
Ive got a set of Team dynamics 1.2s et35 16s running the 300mm disc kit from pure motorsport and they clear the face of the wheel with pleny room but are close to the barrel of the wheel.
dmacmillan
  Clio Sport 172
16x7" OZ allegrita et37 300mm disc
Now fitted with 10mm spacers.
Still wanna try 5mn
Hi there,
Do these wheels no clear the caliper without a spacer?
I understand that an ET35 (net of spacer, if any) is the sweet spot from handling perspective.
Many thanks,
David
dmacmillan
  Clio Sport 172
did some testing with washers, came to nearly 3 mm, so fitten 3 mm spacers now.
Thanks for your reply!
Does that provide 3mm clearance between caliper and spokes? Does the caliper have reasonable clearance from the inner barrel?
I’d be grateful for a photo (or two).
Seriously considering an order (in race gold) for a Monaco blue phase 2 track car. Currently running Turinis - look fab, weight a ton.
Really appreciate your assistance. Trying to organise in NZ a nightmare.
A photo of the wee car follows ...
I Changed My Name
At some point I'll bolt my brembos on and test a 280mm setup with 15" TD 1.2's, 15" Rota Slipstream, 15" Non-sport dynamique wheels and 16" steel wheels. All with and without spacers. I can imagine they'll all need a spacer but doesnt bother me as I already run them as standard
When I eventually get round to putting them on for goos then anyone that needs wheels testing then give me a shout and you can always pop over and slap a wheel on my car and check fitment beforehand
dmacmillan
  Clio Sport 172
bozothenutter
Cheers feller.
So, if my eyes don’t deceive me, we’re looking at clearance of 1mm on the barrel and 2mm on the spoke?
Just so I’m clear, is that is using the 197/200 caliper and Pure Motorsport bracketry?
Many thanks,
David
Nah barrel clearance looks worse than it is because of a raised edge.
but the calipers don't clear stick on weights.
spokes are 3mm clearance (as reccomended by Brembo) scientifically checked with a 3mm brass rod.
Hardware is by a french guy called Seiz, discs are Hispec, hats are Seiz again
VenomUK
  Clio 172
I’m just in the middle of converting mine. I’ve got 15” TD 1.2 ET35, I’ve machined 5mm off the caliper and upon test fitting it’s just catching the wheel. Am I correct in thinking that with ET35 you still need to run a spacer?
Dave182T
  RB Clio 182 turbo
I have the pure motorsport kit, running the 300mm discs with 16" TD 1.2s ET 35 and they have a fair amount of room to spare from the face of the wheel and the barrel. Im guessing yours is catching on the barrel?
VenomUK
  Clio 172
Yeah so the part just behind the spikes. On the lip so to speak. The rest of it (nuts) clears fine
Dave182T
  RB Clio 182 turbo
A little confused. Are the spokes of the wheel hitting the caliper or is the caliper grinding on the barrel of the wheel? If the later of the two, id assume you could just tale a little more off the caliper till it fits? I didnt need to machine mine so not sure how much you can vet away with.
VenomUK
  Clio 172
on the barrel of the wheel. I did think that as we took 5mm off but perhaps it wasn’t enough?
Dave182T
  RB Clio 182 turbo
I would imagine you could take another mm or two off of that all you need but like i said im not sure how much you can safely remove, maybe someone else can chip in.
Clio_fool
The new pure motorsport 280 brackets require a counterbore machining into the caliper 11mm deep, so I think youll be safe to remove a couple more mm if needed.
Jall
  265 cup, ph2 172
I have TDS in the same spec and 280mm brembos, they catch by more than “just a bit”. I reckon I’d need a 25-30mm spacer to get them to clear.
VenomUK
  Clio 172
The new pure motorsport 280 brackets require a counterbore machining into the caliper 11mm deep, so I think youll be safe to remove a couple more mm if needed. View attachment 1477223
I took them to work and took a shaved under 2mm off them now. When I checked I could see I was safe to take at least 3mm before anything would touch the disc hub. Also I have some 1.3mm shims that I can add if I need to add a little back onto them.
VenomUK
  Clio 172
So test fitted again and will Defo need a 3mm spacer to clear the spokes as I’m now fouling those. As for barrel clearance I think more is needed to come off. I Whipped the feeler gauges out and apart from the edges of the brakes them salves I could get as little as .05. Everywhere else was nice. So I’m thinking another .5 off or a whole 1mm off. I should still have clearance of the pad pins from the disc along with 3mm spacer and all should be good. It’s a shame I’ve got a track day on Monday and would have liked to have given the brakes a workout along with all the other changes I’ve done over the winter but c'est la vie.
Dave182T
  RB Clio 182 turbo
Its strange that i have the same wheel and offset (ET35) but on the 16s and have about a 1cm gap from the wheel spokes and the face of the caliper. Would of imagined they would be the same.
Jall
  265 cup, ph2 172
I had no issue with spoke clearance on my 15’s. Rather barrel clearance. I would need considerable spacing for the caliper to clear the diagonal step from lip to barrel.
VenomUK
  Clio 172
So after much tinkering and a 3mm spacer I’ve managed to come to this...
Good or bad clearance?
  • IMG_2246.MOV
    11.6 MB
