Items for sale!
Right then finally got around to getting picture of most items and getting them listed for sale please see the list below, excuse the length of the advert but there are a lot of parts. If multiple people are interested in something it will go to whoever asked first. Please ask for prices on postage as all the prices are excluding postage. Also please bear with me I will reply ASAP. Thanks
Catcams solid lifter finger follower kit £2450 Brand new (RRP £4000)
This kit have been developed with motorsport in mind where engines need to be pushed harder in order to make more power. One way of doing this is by using more revs but the standard hydraulic follower set up will only take a certain amount of revs before it struggles to keep up with the engine speed. Replacing these standard hydraulic followers with a mechanic slipper follower set up allows the engine to rev high and produce more power. Solid lifters on their own can be used but over certain engine speed it is common for the rockers to become dislodged which can cause engine failure hence Catcams have made this kit.
This is a complete kit and is supplied with Inlet cam: 303° and Exhaust cam: 295° camshafts, slipper followers, lash caps, double valve springs, spring retainers and camshaft pulleys. Engine dyno testing has shown this kit to be reliable to 9,000rpm and has been used on a high compression engine to produce 284bhp and 190lbs/ft of torque at 8,500rpm.
ECU Specialist components Typhoon 2 £475
Great ECU for the clio’s be it N/A or boost. Not much else to say really. I can provide with a brand new connector and pins so you can make a loom to suit/piggy back into old one and also have. I have full wiring diagrams and also lots of different maps so good chance I have a base map to suit your needs.
Ph1 cylinder head £100
Unassembled Ph1 head suitable for uprating/porting and just reassembling for a standard head. Will come with valves, springs etc
Door cards £85
CMComposites Black Gel coat moulded fibreglass doors cards for MK2 clio. Includes front and rear door cards which include handle spacers and handles
Eibach 15mm Wheel spacers £50
Eibach 5mm wheel spacers £30
MAD 5mm wheel spacers £25
Pair of Sabelt Silver 4 point Harnesses £125
Sabelt 4 point motorsport harnesses, 3” lap and shoulder straps. Out of FIA date but obviously still perfect for anything other than racing which requires in date harnesses.
Fire extinguisher £250
Lifeline Clubman 2.25ltr Electrical fire extinguisher. Only serviced in Septemeber so in date still for nearly 2 years. Will come complete with 3 nozzles and pipe with p clips along with the tank, buttons and battery pack. Very simple to fit and no more seized pull cables.
Braided Aeroquip fuel line £75
Fuel line with rubber hose adapter to tank then -6 Aeroquip hose with AN-6 red/blue straight aeroquip fitting
Lifeline Q/R boss £130
Lifeline quick release steering boss, Suitable for any 6 bolt steering wheel, allows the wheel to be removed to make getting in and out of the car easier and also is a significant security feature as with no wheel its very difficult to steal the car. This is a quality bit of kit unlike a lot of cheap copies out on the market.
Wheel boss for Mk2 Clio with aftermarket steering wheel £40
Dash (Race technology Dash 2) Oil pressure sensor and oil temp £525
Race technology Dash 2 dash for sale complete with oil pressure sensor and oil temperature sensor (Comes complete with F4R sump with boss welded in for temp sensor)
Race technology Can interface for Specialists Componants ECU £95
Allows all the information the ECU see’s to go to the race technology range of dash displays.
Megane injectors £100 per set (2 sets available)
Pure Motorsport Top mounts and strut brace (Gloss orange) £175
PMS top mounts complete with bearings and strut brace, Strut brace is powdercoated orange.
Clio 172 Cup alternator £80
Cup alternator (75Amp) been used on my car for a year faultlessly connector for check light is damaged but obviously doesn’t affect how it works.
Clio 172 Cup brand new genuine Alternator £140
Brand new alternator from Renault that I carried as a spare, plastic on the connector for the checklight has been cracked in my spares box but doesn’t affect function.
182 Exhaust manifold (no dent!) £100
A very rare undented 182 exhaust manifold. Most have been dented but this one isn’t!
Mocal 2ltr ally Catch tank £80
Catch tank meets MSA requirements and includes custom made bracket in orange and includes breather hose.
Driveshafts all genuine Renault 182 non cup.
Passenger side 1 year old (9 hours use) £75
Drivers side 1.5 year old (14 hours use) £75
Passenger side brand new genuine in box £125
Drivers side Brand new genuine in box £125
Cmcomposites brake ducts with deflector plates £120
Black fibreglass brake ducts with deflector plates, great bit of kit and much better fit than the cup racer items while still looking similar and functioning just as well.
Cmcomposites front splitter £120
Black fibreglass/carbon motorsport front splitter overhangs around 8cm
1*2 front bumper genuine Renault £120
Only used once and never painted. Cutout for aerocatches and holes for cooling.
Genuine renault front bumper and grills unpainted (Only used for 1 race and no damage) Includes top grill also only used once since new
IMG_7031_zpszs95jcf9.jpg.html
182 rear bumper with exhaust trims £50
No splits/cracks etc
Lifeline LED rainlight £75
FIA approved rainlight, The best rainlight on the market used in most professional GT cars and single seaters.
Flocked 182 dash top £75
Black flocked Dash top no vents and cut for roll cage, comes with carbon fibre fibre back plate for dash binnacle
Cmcomposites roof vent £150
Cmcomposites centre dash console £40
Fibreglass centre dash section suitable for mounting gauges, switches etc
Drivers carbon false floor £75
Carbon fibre false floor for lifting drivers feet to a suitable height when carpets are removed.
Heated windscreen (only used once) £200
Great way to save weight by removing heaters and switching to a very simple but effective heated screen. Very easy to wire in and works really well. Tiny stone chip but reflected in price. Paid £300 just before the last weekend the car did.
Brand new headlights £45
Non genuine headlights work perfectly and include bulb holders.
Front wings £20 each
Genuine Renault wings one is silver the other is painted white
Lightweight TTV steel flywheel for 7 1/2" clutch with Helix clutch £695
The ultimate clutch and flywheel kit for a 1*2 includes TTV billet flywheel, Helix billet cover assembly and 4 paddle cerametalic solid plate. Includes ARP bolts to fix flywheel to engine and also bolts to hold clutch to flywheel. This really is a proper bit of kit to eliminate the risk of clutch failures. Also comes with uprated release bearing. Only used for around 30 mins so like new RRP is circa £1K
PMS stud and nut kit x2 £85 per set (16 studs and nuts per set)
Coil pack bracket £40
K-tec coil pack relocation bracket for ITB’s
