Cub's Flamer - Supercharged, Cage etc
Cub.
Spec update;
Engine
- 182 Engine, rocker cover painted white, block painted black.
- Rotrex Supercharger kit with associated boost pipes.
- Gen90 ECU
- Toyosport Intercooler
- Custom Roose Motorsport hoses
- Samco Coolant hose kit
- Magnecor Leads
- Mocal Oil Cooler
- Mocal Catch Tank
- ARP Rod Bolts
- K-Tec / Vibratec Solid Engine Mounts
- Matched Inlets
- K-Tec 3.5" Recessed Supersports exhaust
- Megane Injectors
- 102k miles, new cambelt, dephaser, megane keyweyed pulley and megane crank bolt fitted and timed by Dan@SJM
- Powdercoated inlets, fuel rail guard, engine mount and brackets
- Bosch S4 battery
- Air con delete
- Nimbus heatshield
- Mapped by RS Tuning, Rolling Roaded at 248.7bhp and 220 ft lb.
Transmission
New Gearbox
- Gripper LS Diff
- PMS Race Shifter / Gear linkage
Handling
- Bilstein B14 Coilovers
- Whiteline ARB
- Eibach Hubcentric Spacers (16mm) all round
- PMS Solid Top Mounts and Strut Brace
- Eibach Camber bolts
- -2.5 deg camber at the front, 10 mins toe. -1 deg camber at rear
- PMS Stud and Nut kit fitted
- 15 Speedline Williams wheels
- Cup wishbones fitted
Braking
- Brembo 4 pots (Megane 225)
- Custom HEL braided lines
- Custom Chris Powell Brembo brake brackets
- ABS delete (incl. Loom), full Cup brake lines and MC setup fitted
- Ferodo DS1.1s, Ferodo DS2500s rear.
- Brembo grooved HCs (Front)
- Renault OEM Discs (Rear)
- ATE Super Blue Racing brake fluid
- Fog lights removed and no arch liners
Interior
- 2x Sparco Evo 3 Bucket Seats
- OMP Subframes
- OMP 3" Harnesses
- Custom Oreca / Renaultsport 330mm Steering Wheel
- OMP boss
- 6 point Roll Cage
- K-Tec Rear Boot Mat
- Renaultsport Front Mats
- Sony CD Player with Ipod Connector
- White Dash Strips & Gear Insert
- Alcantara Handbrake Cover
- Rear Strut Brace
Exterior
Cup Splitter
- Trophy Spoiler
- Renault Sport 197 Badge
- Porsche 'Bee Sting' Aerial
- Lockable Aerocatches
  RB Clio 182
Nice mate, thats some spec!
How do the aerocatches work mate, i wouldnt mind some.
Do you open your bonnet with these and how do you open/lock it?
Does your standard bonnet catch still work?
Cub.
Cheers dude.
Aerocatches replace the pull / bonnet catch in it's entirety. You basically push them to open them. I'd recommend locking ones... :smile:
  RB Clio 182
Cheers dude.
Thanks Cub ill look into it, they look good imo, it makes you think "wonder whats under there" :tongueout:
  330i. E30 Touring.
Nothing at all untidy about the catch install in my eyes.
To finish, get a file out and take any sharp edges off. Then get some pink nail varnish and touch in anything silver to prevent rust. simple.
Matt_90
  Sprint/climb 106 gti
Car looks awesome mate, bet it goes well with the charger. Look forward to seeing it at some point.
Cub.
@Rob With a spare 10 minutes this morning, I took one of the wheels off for some more photos. Yes, some of them aren't brilliant, but I'm not David Bailey and I don't intend to spend time trying to be so jog on @Daniel. :)
And the mincing hero that is @NorthloopCup send me some of these 'work in progress' shots of my new hubs, which he has kindly painted with his dainty hands, thrown new bearings into them and is awaiting a few off here to finalise payment so they can get the roll centre adjustment bits on :) I'm sure @Phase1sr will approve of the shiny nature.
I'm awaiting for the willys wheels back from the powder coaters, and kindly @BIGASH is going to act as my tyre supplier, so we should all be set for Bedford on the 28th. Need to do a few road miles in the clio to bed the brakes in, as it hasn't moved further than 2 miles for nearly 6 weeks. Current dirty car fleet, with trusty micra steed front and centre 😂
SharkyUK
Well, you're no David Bailey... :tonguewink:
Off topic... but why are the desk tops fitted upside down?! Or are those holes where the divider panels fit? Anyways, I digress..
Looks good mate. Definitely one of my favourite cars on the forum :)
NorthloopCup
Looks good mate. Definitely one of my favourite cars on the forum :smile:
Yeah there used to be dividers there, but they decided that they made it feel like a 'closed in unfriendly environment' as you couldn't see people's hands?! Seriously, wtf???
Matt_90
How cute ... the brakes have their own thermometer! :p
Looks good mate, looking forward to seeing it at some point.
