Cup racer project finally finished
  Disco 3 &4 1993 mini
Re: clio cup race car project!
glass matey, gona give it a year or so then think bout getting plastic windows and fibreglass panels
quick addition to the car this afternoon
i made sure i got the internal ones so that not to interupt the aerodynamics of the car
right didnt do too much today but got a little update. id remembered id got a pair of rebuild kits for the front calipers. so i set about taking them apart
and oafter a bit of wire wheeling they looked like this
i had some paint left over so gave them a quick coat
so i set about rebuilding them
i wire wheeled the sliders put new grease and boots on
cleaned up the pistons and put new grease on and slid them back into the caliper
and the finished article
i also got some brake lines made up by Matt and Think Automotive 02085681172
he did an awesome job, really good quality.
thats all for now more next week
  172 Race Car
they full length flexable brake lines? to run inside the car?
Are these a copy of the bits you took off or have you measured etc?
yea they are full length flexable hoses to run through the car with a bias controller inline. when i got the car there were no brake lines at all so ive measured the required length and had them made up to that length.
haha yea after i remember how i used to do them it was fine
I always prefer as much solid line as possible due to improved feel over lots of braided. Braided is much tougher than rubber brake hose but still has some give and over a long enough run its sufficent to feel.
The original Noble M12's were braided throughout the entire brake system and we got very good results in terms of brake feel by changing the vast majority of it for old school copper.
M
didnt do much today as was working but realised i had a power steering leak.
found out that there is a big crack at the top where the pipes connect so that means a i need a new steering rack hopefully supplied by the team i do some work for.
im pretty sure its just a standard 17/82 lhd rack someone correct me if im wrong though
  TrackCar & F30 330d
Oooooooo i'm so jelous. Look like a great project. cant wait to see it finished.
here a few pics for you in case your interested, the bottom one shows the offeneding crack in the steering rack.
  Qashcow
hardcore erotisism at its best (is that a word?) either way, fooking love this car
  s1 williams/106gti
:(and i thought i had the best free car on here :(
*RUNS AWAY WEEPING*
  Clio Cup Racer
Good to see it coming along. :)
The yellow one is still going.
Sorry to see that happened to yours once you sold it Super Touring. :( Have you got any new toys yet?
  1.2 8v 60bhp
thats the way id want my clio ride height at the back, what size of wheels are they? and what size of drop? thanks
they are 15inch wheels and i have no idea about the drop mate sorry
fil_b
  172 FF and Fabia VRS
bit low at the back lol
looking good lee
you can see how little the wheel has dropped when the car is in the air.
M
mini-valver
This is something I've bveen wondering about. When I put the car on a 4 poster, the rear springs drop out. When I'm cornering hard and the back wheel lifts, is the spring going to come out??
  lift number 1 @ btm
can happen!
my rears have helper springs on to stop dislocation.
M
mini-valver
FFS, shitbox FK's. Aside form raising it, which I dont want to do, is there anything other than that??
  lift number 1 @ btm
not sure to be honest fella, are the springs on yours straight or egg shaped?
  ITB'd MK1
"shouldn't" happen due to the axle design. Being that the rear isn't independent, you get both sides doing the same thing, so one side is pushed into the arch, the other will follow. you have to allow for a certain amount of flex obviously.
can't see that happening tbh because like danny says the rear axle isnt independent which means if the one wheel is weightless the other will still be under load making sure the axle doesnt drop enough for the spring to fall out.
  Qashcow
yea got to agree with you and danny, the whole rear beam will move so the FK's springs wont fall out. i believe H&R's are he same too
and to the other person who asked, they are (at least mine are) bubble type at the rear, not straights :)
back on topic lol
