I said I'd do Dom a list of engine mods that I've done as he's doing a forged engine too, but I thought I might as well do an upto date list on here as the cars about finished now in terms of any more mods being done.
Engine
2.0 16v F4R
Fully rebuilt
New thrust washers
New big end bearings
New main bearings
New OEM oil pump
Supertech Inconel One piece valves
Cat Cam valve springs
Cat Cam 438 cams
Cat Cam rods
Custom CP pistons - 83mm
ARP rod bolts
Cometic head gasket
Rotrex C30 94 supercharger (Brand new)
Custom pro alloy inter cooler
Custom pro alloy slim radiator
Custom slim fan
Mocal oil cooler for charger
630cc injectors
Megane sport spark plugs
Megane sport crank pully
Helix organic clutch
Ported out Ph1 cylinder head
Matched inlet manifolds
ITG air filter & custom pipe work
K&N breather filter
Black silicone boost pipes
Samco black coolant pipes
182 exhaust manifold
K-tec 2.5" decat/link pipe
K-tec 2.5" supersport stealth cat back
Vibratechnics engine mount
Vibratechnics gearbox mount
Powerflex dogbone mount
Iceberg silver engine cover
Polished inlet manifold
Using Millers Nanodrive CFS 5w40 engine oil
All engine brackets/mountings & gearbox mount powder coated
Wheels & Tyres
16" Renault Oz F1s in gloss black (197 centre caps trimmed down)
205/45/16 Federal RS-R track tyres
Brakes & Suspension
197/200 Brembo 4pot calipers
Custom brackets
197/200 Goodrich braided front lines
Scenic 300mm brembo front discs
197/200 Brembo front pads
Goodrich braided rear lines
Standard OEM rear discs & pads
Polly bushed bottom arms
Polly bushed ARB
FK Highsport coilovers
K-tec bolt in solid top mounts
Fk 20mm hubcentric front spacers
Bottom arms, ARB, Subframe powder coated
Interior
Ph2 172/182 dash conversion
Ph2 172/182 door cards
All Ph2 interior trim to suit
Dynamique black carpet
Recaro treadline front seats
Ph2 172 rear seats
200 steering wheel (yellow stitching)
'A' pillars & sunvisors painted dark grey to match dash
Ph2 172/182 sun visors (lights wired up)
Ph2 172/182 interior door handles & handbrake button
Satin black grab handles
Titanium dash inserts
Ph2 172/182 clock surround in satin black
Aux output for iPhone
182 front speakers in the rear
182 tweeters in the rear (either side of parcel shelf)
Exterior
Sunflower yellow
Fully colour coded
Ph2 172 side strips
Ph2 rear lights
6k HiD kit
Clear side repeaters
Silvervison indicator bulbs
Rare genuine Renault spoiler
Master van door lock blanks
Ph2 Megane front splitter
Carbon wrapped scuttle panel
Carbon wrapped fog light surrounds
Fog lights removed
Private plate C14AGD
Tracker system fitted.
Performance
320bhp @Flywheel
270bhp @Wheels
240lbs ft torque
1000kg = 320bhp per tonne
0-60 = ? It was 5.2secs running 260bhp & only T1R tyres, would hope its abit less now.
Future Mods
Standalone ecu
Maybe a LSD but probs along as I've got the 197 for track days I won't buy one.
Wheels powder coated bright OEM silver
Standard Ph1 side trims & door handles
Ph1 rear lights
After its had it's magazine feature I want it to look as OEM as possible external & enjoy it.
