BIGASH/FF-Racing X85 Clio Cup Racer Project
Must not put this in tyre wall.......
Would fibre glass be any lighter than the plastic? Or is it just the design and ease of making it, that you are using fibre glass?
Looks awesome by the way, and I've just copied and ordered the same! Hope you don't mind.
No it's going to be similar weight but less flex and can mould the splitter, brake ducts, top grill into it and will make it much better in my opinion :)
Haha great stuff, don't mind at all that's what it's all about!
@BIGASH you don't fancy wrapping my car do you?
Hahaa sorry no afraid not buddy! Don't have time unfortunately and it's okay on a race car but it's not great when you look up close. The car is going off for spraying over winter as I'm thinking painting will be easier than wrapping lol
Another day of getting the car ready but all done now just a few stickers to stick on once we get to Silverstone tomorrow night :)
Car went off to Bubble & Kick Racing for geo doing :)
Lee's customary pose ;)
Cutting the stickers
Continuing the orange theme
All loaded up and time to fill up the bus
Arrived safe and sound in MK :)
good to see this turned around so quickly. May try and get across to silverstone on saturday also.
would be good to catch up with a few faces and also see some racing
Car looks awesome :) and MK, as in Milton Keynes? Lol
Thanks! Yeah got a place in Milton Keynes don't spend much time there but that is 'home'
I want that tow car.
I love it, think it's probably the best car I've ever had tbf it's so good at so much!
Thanks buddy! Would be great to see you and I should have lots of tickets will confirm tomorrow and let you know.
Right then Birkett weekend! So the days leading upto the Birkett were filled with getting the car ready which involved getting a new rad made, repairing the wrap in a few places and adding some stickers. This was done and I set off to Milton Keynes on the Wednesday night.
Now since the trackday at Oulton where I suddenly felt like the car was down on power I had been concerned but everything checked out okay we did compression check, checked the fuelling, fuel pressure, injectors, dyno and everything came back okay but it still didn’t feel right. So when I took the engine out to swap the clutch I put one of my other engines in just to try it for the weekend and see if it fixed the problem (Trying to see if the issue is with the car or with the engine) So I put the other one in and was booked in at Bruntingthorpe on Thursday just to check the fuelling was safe for the weekend between the different engines. Thankfully it was very close and safe so that was good but the oil pressure seemed a bit on the low side. Wasn’t too low but was lower than the other and it didn’t want to risk it going bang! So me and Apex Lee hatched a plan and both shot down to Essex Thursday night to collect the other engine and the engine crane and then instead of testing in the morning on the Friday we would swap them over.
Friday morning and out the engine came we managed to get the whole thing out and gearbox off in 45 minutes which is a new record for us! The plan was to rush the swap and get out for the afternoon testing but then the heavens opened and we decided against testing. So we had a bit of a break went for some food with @Tony Hunter and had a good catch up and then had a gentle afternoon of putting the car back together. Once that was done it was time to clean the car, get the stickers on and get the car scruitineered. The car flew through and we were all set for racing the following day!
Here we go again!
Stickers
Scrutineering
Racing kit!
Tucked up for the night
Myself and @LeeP86 went off for food with the team we were racing with and tried to get an early night!
Race day came and it was a nice bright morning. We gave the car a quick once over and then it was time to go out for the 20 min practice session (In the Birkett the qualifying position is determined by previous lap times so we were 12th on the grid out of 70) I thought the track would be drier than it was but it was quite wet and I was on the dunlops so it made for an interesting session the main aim was 3 laps as without that you can’t race. This was done and then pushed on a bit and the car felt okay :)
Back in and it was time to line the cars up in race order and give the car a quick once over, Breather hose needed some fettling and a quick tweak here and there and all good!
My first stint came around and you have to sit in the car ready to go incase the car before you has an issue so sat there for 30 minutes wasn’t what i’d planned but went quite quickly :) First lap of my stint and the car kept throwing itself out of 4th gear, it kept doing it again and again and wasn’t good. So I ended up resorting to driving one handed most of the time and holding it in gear which was a bit sketchy to say the least round some of the quick corners on fairly cold tyres. Unfortunately after about 12 minutes of my stint there was a safety car for a huge shunt between a Radical and a BMW I really hope the driver of the radical is okay the last I heard he is in a critical condition in Hospital! So I followed the the pack around until the end of my stint and then into the pits.
With the car back it was time to work out what was wrong and causing the car to jump out of gear. Our first thoughts were the engine mounts namely the bottom gearbox mount and the dogbone mount. We rocked the engine with the car in gear and could see abit too much movement, I had a spare of both mounts but it seemed to be the polybush doggone mount so I swapped this for a standard one.
2nd stint and it was quite a bit later in the day the pace seemed very strong with the whole grid and the track seemed to have more grip, it was a great stint and the car was going really well the gear issue was sorted (Dogbone mount) and just generally had lots of fun. Caught upto a Boxster S race car that was very defensive but it was quite good fun. The thing with the Birkett is you have some car doing lap times in half the time some other are doing and normally when racing you don’t have such a spread of performance but it was good fun you just really have to be alert otherwise danger is only just around the corner. My stint was 30 mins long and then it was over the car had performed very well and delivered a lap time much quicker than I had expected so I was happy with that especially without any clear laps. We stayed to support the team until the end and it was a great feeling to be part of a team regardless of finishing position.
So the car is in one piece and pretty much ready to go again next weekend at Snetterton I’ve ordered an Evol Engineering doggone mount to see how that goes with the gear shifting. I think the car needs the geo doing again and maybe fit the new bonnet if I get time but other than those small bits I’m happy and bring on next weekend!
I’ve got to say a massive thank you to @LeeP86 for everything he has done and his motivation for swapping the engines without his help the car wouldn’t have made any races this year so thanks buddy! Also huge thanks to @Tony Hunter for getting his hands dirty and helping out get the engine in and also lots of other help over the weekend with Stickers, molesting me etc ;)
I will get more photo’s up as I get them and also will put the videos up once they are done!
Thanks also to everyone who came to watch and give support Lee, Tony, Neil, Mark, Natalie, Sean and Sophie it was great to have you all there and catch up along with everyone else who we saw over the weekend was lots of fun!
Nice write up mate, didn't realise you'd had the engines swapped out and back again before hand, nice work!
I assume there were 6 cars in the team if you did an hour stint (2x30mins?) just interested in how it all works as I've said it might be something I'd do next year. 2015 All clio team, you, me and some old blokes @Tony Hunter and @mitsiman
Russ
Great write up mate, a lot of hassle, i would prob have thrown the towel in by now, so well done to you both.
Cant wait to see the race footage. So where did your team finish ?
Thanks mate, we finished 39th out of 69 scratch position and 49th in the Handicap
Can't beat a bit of molesting, helps the time go.
Good weekend.:cool:
Yes great weekend really enjoyed it :)!
Russ
Yes 6 cars in the team Russ but drivers can share a car :)
I did try and sort an all clio team early last year but there was very little interest. Obviously there are more clios now and I think it would be good fun :)
I'd be up for this next year.
Perfect :)
I'd be up for that next year!
Well done James, see you at Snetterton!
Great stuff!
Thanks Andrew see you then :)
I like the new livery. A lot.
Good work chaps. I need an @LeeP86 to cart about and wheel out for engine swaps.
Oh. I have one. @Budgie :smile:
Thanks buddy was mainly because we had run out of grey wrap lol!
Haha :)
Looks so much fun. Shame about the 4th gear issues.
That Porshce Boxter race car getting in your way a bit towards the end.
Love the way there's radicals and the likes scooting about all over the place too.
