hellloow..
So recent events have forced me to part with my 182 (which can be seen below) lots of money has been poured into it as you can all understand, and is currently up for sale.
It recently underwent a bit of surgery due to a crunching 3rd gear and a dodgy starter motor,  so I decided to remove the engine as a hole, as before the sale it would give me a good oportunity to clean it up - my thought process behind this was last time i removed a 182 box it was by dropping the subframe on my back on a gravel drive - it was unpleasant!
So I began sourcing stuff I needed, I borrowed an engine crane from a
@CUB off here, who was very helpful providing that, and when I say stuff that was all I needed really.. haha but yep top man he is!
Here's how she started.
A during showing state off engine etc
So it was a big learning curve and it was the first time I removed an engine, but it came out without any issues which I was pleased about.
and there she is back in and all cleaned up with no issues, apart from the live wire of the starter motor was touching the trigger wire... when I connected the battery I thought I had managed to hotwire my car as it started turning over...
Sorry about that little progress on the 182...
Moving on...
In addition to this I have bought myself a run in 132k phase 1 - I've always wanted one and now is probably the right time to, the title suggests this will be tracked, and further down the line when a daily is sourced - it certainly will be.
I bought it very much standard, it hasn't been  looked the roof looks like someone's had a dance on it, but hey its cheap and the front end is cool af.
Picked her up from Devon
First thing I did was change the rear lights to ph2,  but not I'm very much regretting it since I picked up a cup spoiler... 😧 (for £25 bargaaaaain)
following that, i restored the headlights using the usual method
It was raining, and garage space is minimal...
2nd update was to replace the drivers side door, which the guy had supplied - turns out a Ph2 door will fit in a 197
also put some ph2 bump strips along with colour coded door handles... which is a Ph2 mod I do stand by! haha
So I'm currently in process of relocating the battery to the boot just waiting on a
