I'll get some up over the weekend. Spent the afternoon doing the wiring and that's nearly finished. Got lights and a fuel gauge and everythingInterested to see pics of your dogbone, I have an idea in mine for mine, but its not using original dogbone
Sent from my SM-G935F using Tapatalk
Yeah get some pics of all your wiring aswell! Did you just use your own loom/ switches for all the lights, indicators?! Or did you wire them into the clio stalks?I'll get some up over the weekend. Spent the afternoon doing the wiring and that's nearly finished. Got lights and a fuel gauge and everything![]()
Plugs for the eps ecu, luckily I took this before I chopped it off. Bridge pins 4 &5 and 6&7Hey mate two things:
- that ecu plug that your bridged have you got photos, i know someone else having the dash cluster illumination problem.
-while your at that stage, can you measure your driveshafts, I bought a pair already done just want to compare lengths... :wink:
That's a right royal pain in the arse. The shafts are in on mine, like I said passenger side is okay but drivers side there's bugger all in/out movement so it's effectively fully compressed but the wheel turns fine and it looks to able to get enough negative camber so I'm hoping it'll be alright for Wedensday. After that I'm going to pull it out and get it shortened or get a new custom shaft made as there's a couple of places round here that do them if you know the length you need and number of splines.Good work bud, not long left!
Where the driveshafts from bernie alright in the end? As the shafts I bought already made I cant find a outer clio cv joint that fits, well on the long side... the short side is fine.. its a bit of a bodge the outer 'shafts' are different #fuckingannoying!
I've run out of time off for this year so hoping to be home by 3ish this afternoon then just going to stay on it until it's done.Good effort pal, sounds like my last track day, ended up taking last minute days off and finished 11pm the night before and left at 5am the next morning!
Just been out in it. Feck me it's fast.
So looks like it'll be going for alignment tomorrow and getting the R1Rs fitted. Going to get the garage to check the brakes over as well for my piece of mind.
Problems at this point - speedo doesn't work, only got 2 abs sensors connected, will connect the other two, if that doesn't work then bin the ABS ECU as that's all I've kept it for and either use GPS or get an aftermarket speedo. Also need a spacer for the wheel as the pedal boxed has moved where I need to position my seat and wheel's too much of a stretch now. Somehow managed to wire up the passenger side rear fog instead of the indicator. That's about it![]()
Mounted underneath, cut the studs off and drilled holes, clips into place like its meant to be there. Positions good but you'll want a short shifter, makes it much better. Got myself a camera mount for my iPhone so will get some pics and videos up over the next few days once I've finished fetling it.Epic!!! Yeah i think ill be running a gps speedo.
Hows the shifter position aswell? Did you mount it underneath or on top of tunnel?
God you've made me more excited to get mine running!
Hahaha stop it! My gripper hasnt even come yet!Mounted underneath, cut the studs off and drilled holes, clips into place like its meant to be there. Positions good but you'll want a short shifter, makes it much better. Got myself a camera mount for my iPhone so will get some pics and videos up over the next few days once I've finished fetling it.
By the way, turbo noises are the best thing ever :smiley:
Err.. Up against it. Currently still at the garage. Alignments been done and tyres fitted, one of the front callipers is binding so they're fixing that. So I'm leaving work in 20 minutes to go and get it as they haven't said it won't be ready.Update?!
Good luck! Im sure you wont need it! Pic of lower dogbone when completed something to compare mine to hahabErr.. Up against it. Currently still at the garage. Alignments been done and tyres fitted, one of the front callipers is binding so they're fixing that. So I'm leaving work in 20 minutes to go and get it as they haven't said it won't be ready.
Need to make a new lower engine mount tonight and some other finishing off. Hopefully proper update tomorrow assuming it doesn't breakdown or I bin it
Take a toolkit to Oulton :wink:
Not long now!
Peel the foam back and there's 4 screws hidden under neath. Then need a flat blade screw driver to pry it open@Matt555 where are these secret screws? As i want to seperate the shifter to make sure Im not drilling the bias valve in to anything... err shifter like
Cheers bud,Well we made it and now it's dead
The Megane I literally drove up and down our street after it was delivered then set about pulling it apart. I assume its just luck of the draw on buying a written off car, or indeed any second hand car. Just making a start pulling it apart again :weary:Such an anti-climax mate
As you said, mad rush, this is bound to happen but its awesome it made it there and it drives etc.
Not liking the sound of smoke, rattling and bag of spanners sound though... Did you drive the Megane before this all happened? Or do you think it's more to do with it being rushed together etc?
Keep the faith !
