Daily dci
Brigsy
  T.Turbo
Mpg seems to be awesome on the blue dci @Mazz it does do a fair bit of dual carriageway driving though. The orange one does around 62mpg with a mixture of street and short dual carriageway runs, so yours sounds about right.
Id leave cat off and egr blanked. The blue one is smoking bad from cold now and assume oil control rings are stuck due to oily crap building up, these engines are dirty and the egr chokes them up. Ive got the parts in stock to give it a freshen up very soon, im thinking about spinning the egr 180deg when its back together aka cheap delete.
Martin_172
Mine ran brilliant after I disconnected it while closed so it wasn't doing anything! Night and day better, performance, economy and just general running!
Brigsy
  T.Turbo
Did it chuck the eml on ? Ive considered modifying the pushrod on the solenoid.
Martin_172
it never brought the light on once in 30k, HOWEVER it was running a superchips map so I'm not sure if the EML/EGR had been disabled, there was certainly nothing in the description to say it had but my old standard 65 used to bring the light on with the EGR disconnected.
Brigsy
  T.Turbo
Xmas repairs to the blue dci.
Epic amounts of blue smoke/misfire from cold now. Ready to pull pistons out tomorrow, bores are nice and shiney, i guess that explains the epic oil usage. Evidence of previous inlet valve to piston clatter on cylinder 1&4, i had a feeling it had a head job previously.
Pikey flex hone in situ tomorrow.
plees
  S/C Iceberg 172 Cup
Pulling any money? Last derv one i done got £30 for. Got a ph1 225 cat here might get that gone;)
Last kangoo one I got rid of I got £77 for. But an earlier kangoo was only £30. Swings and roundabouts! That 225 cat will get you something nice for Christmas no doubt!
Brigsy
  T.Turbo
Cat needs to go but cant be fucked paying somebody to make a pipe up.
Keep it going for a few more miles while looking for a replacement @Adeyspec . Ive been looking for suitable diesels for work but a lot of scrap about for 2-3k at the moment.
Speedo Gonzales
If you knock the guts out of that cat and put it in a bag I can get you the same money for it. Tommy pays for the material as long as you can send him the code
Speedo Gonzales
Ill have a look and see if i can get in with the bar @Yorkshire Pudding (y)
What was the mk3 like on diesel @Adeyspec ? The mk4s we had at work were good for 50mpg from memory.
You should be able to smash the internals out with a prybar if I remember. If not you can cut a slit and then just peel a window on the part that sits against the block. Nobody will know👀🤣
Twingo 1??
  Twingo 133 Cup,
Don't know if this helps but my Megane mk3 110 gets 50-53mpg. I only paid 550 for it and seen a few about 1k.
Speedo Gonzales
I don't get why they're so s**t on fuel. My MK2 dCi 100 did 80mpg average
Newcastle to Brighton at 60mph did a steady 92mpg. I'm fairly certain it was running on the fumes coming out of the cars Infront
@Gus has/had a MK4 that he does silly mpg in iirc
plees
  S/C Iceberg 172 Cup
They any better on fuel without the cat in with it being more free flowing?
What they like noise wise? 👍🏻
Might have just given myself another job to do!
Speedo Gonzales
My pal decatted his 80 when the engine went pop. There isn't much noise added apart from a bit of turbo whilstle, bit more smoke but he's still got the backbox in place
When he starts it I tend to sniff up harder, f**king love the smell of diesel smoke🤣
VenomUK
  Clio 172
Always on the hunt for more MPG!
So if I take the cat off (or internals out) on my MK2 Kangoo 1.5 dci I’ll get better MPG over my current (which is already good)
Brigsy
  T.Turbo
I could live with 50+ mpg so might have a look at the newer clios.
Blue clio back together.
Fired up first turn, did not need any sniff to get it going which was good. No blue smoke from cold so looks promising, engine sounds great even quieter than before.
Took it for a ten mile drive on some local b roads with hills using peak torque/boost to get some load on the new rings to break them in. Will run it on mineral oil for a thousand miles or so before going back to synthetic.
The Dan Grenade
  Whichever has fuel
@Brigsy - I used this for a looooong road trip last week. Did nearly 70mpg! (Think it was 68.8??)
I think they are really good cars - and a step up from the Mk2. Sadly, the seats in the mk3 are abysmal. Like sitting on a temporary camping stool/walking stick combo. You could literally fall
Off at any given moment. 😂
Brigsy
  T.Turbo
Decent that @Daniel . Ive only drove a 197 with recaros before not had the pleasure of driving a povo yet. Cant be any worse than some of the heaps of shite ive drove in the past though :LOL:
VenomUK
  Clio 172
Reading this has made me want a MK2 dci.... are there any on the market for a few quid....is there f###
