Adey.
Managed to finish off the fuel side of things. The Cooksport fuel rail is a nice bit of kit though the injector clips are a pain to fit to it, I ended up fitting them from the underside (in case anyone else looks here and has an issue) Re plumbed the fuel lines with some 8mm high pressure e10 compliant hose. Nothing fancy but functional
The fuel setup should now be good for over 300bhp without the end cylinder running lean
Oh and I took a delivery of a set of Megane 250rs pistons and rods which I may use in the future
