The VW Audi Skoda Seat Thread
Joe#
Had mine in for a service a couple of weeks ago, and they confirmed it had the infamous coolant leak from the thermostat housing (I’d been topping it up every so often). Got it sorted by the lads over at KWJ in Warrington before heading down to South Wales for a few nights away.
Matt Cup
  Leon Cupra
How much was the thermostat housing fix? Did they do the pump too? Mines under warranty still but it’s always in the back of my mind.
Matt Cup
  Leon Cupra
I paid £671 with the water pump included. They all seem to let go at different times, so it’s pot luck really. Mine’s on 55k miles now, which is pretty good going compared to some.
Do they put a revised part on it or is it a case of playing roulette again?
davo172
  TCR'd 172
Alway get pump and stat housing both changed, If you don't it will leak again soon mine did.
I had just the stat changed under warranty then months later it liked again I traded it in then so wasn't bothered.
Starlet_gt
  VW T5.1
davo172
  TCR'd 172
R3k1355
Have just replaced the AC compressor and condenser on my Leon (Mk6 Golf platform)
What now? Do I have to inject oil into the compressor? Can I drive it to a place to get the AC charged, will they have the PAG oil?
Also, f**k this job. What a total pain in the bum!
Matt Cup
  Leon Cupra
Can you use one of these kits which has gas, oil and sealant till you get it to a garage?
R3k1355
Yea I've got the filling kit and the can's are not expensive, are they ok to fill a system from empty? They only connect to the low pressure side of the system.
or does it need a professional kit because it's completely empty?
Flob
@Scrooge knows about this stuff but I've always been of the understanding that to properly fill the system you need to vac it first which also removes any moisture.
I accidentally turned my Clio ac pump upside-down when it was off the car and poured all the oil out, I bought PAG oil and refilled it however there was really no spec on line (that i could find) telling you how much oil to put in so I guessed, I also didn't think the proper garage style refill systems added oil?
Anyway, Scrooge will know and won't be just making stuff up like me.
Scrooge
  E55 AMG
Always use a proper machine with a proper set of gauges imo.
If it’s empty it needs a vacuum etc I also like to fill with nitrogen first as sometimes systems leak and don’t show on vacuum etc
You also usually need something like a Maxidas to double check pressures and make sure everything is working correctly. Mobile Ac. Guys tend to have these
The can are a false economy
cat171
View attachment 1753166View attachment 1753167View attachment 1753169
American EZ conversion. 1600 on twin carbs with a nice interior conversion. Slightly lowered on replica wheels. Has later braking system with discs up front. Bottom of the pile for Splitscreen officianos and with plenty of patina but one I/we can use and for once a vehicle the Mrs approves of!
Nice one!! Is it LHD or RHD? (can I work this out from the position of the wipers?)
I've always wanted one.
Hyperhatch
@cat171 Thanks. It’s a German van that would have been imported new to America so is LHD. It came to the UK in 2012. Fingers crossed we should be getting it next week 🤞
BIFCAIDS
  340i M-Sport & 182
I replaced the inlet valve on the A3 like 12 months ago and then started getting the ol' engine management light and starting to shudder on shut down. I've since learnt these VAG bags of w**k need to have the inlet "Coded", do you think that's what is causing the issue again, a brand new unit shouldn't have failed after 6 months surely?
BIFCAIDS
  340i M-Sport & 182
How you getting on with the 320?
Absolute dream, we've had 2 issues but relatively straight forward. Creaky top mounts, £50 a side and track rod arms at £55 a piece, but that was because we took it for alignment and they were seized. Mrs loves it, I weirdly love it.
