BIGASH/FF-Racing X85 Clio Cup Racer Project
Re: James/BigAsh 182 Race Car by TDF... It doesn't get much better than this! *Pic He
Can't wait for the write up.
Gutted I couldn't make it mate - loads of stuff piled up on me this weekend :(
I've just realised I'll be over in north wales when the Oulton Park race is on though so i'm coming over for that :D
When is Oulton as ive a sprint at Angelsey on the 7th Oct ?
Wel done James, I expect you to be battling with burpspeed next time out.
Not chance, hes the number 2.
Slingshot engauged
Shake n' bake baby
Well done James, I didn't post good luck as I didn't want to put the mockers on you lol, then when they said you'd thrown an aux belt in practice I couldn't beleive it, and again well done looking foreward to the videos.
Regards Russ......
Thanks Simon :) Good to see you again yesterday! Haha lol now that is positive thinking but its certainly not an aim for me was just nice not to be lapped by them for once ;)
Slingshot engauged
Shake n' bake baby
Hahaaa lol :D
Regards Russ......
Thanks Russ, Would be great to have you and Colin on the grid next year if you guys can!
James we all know you'll be at oulton come 6th oct with your RACE car on the grid. Lol
Still a few little things to sort out for the next race and do some pit stop practice lol
Haha the list of current jobs is below:
  • Re-wrap side strip
  • Touch up wheel
  • Remount, both bumpers
  • Clean inside, outside and wheel arches
  • Investigate front brake calipers
  • Refurb rear calipers or replace (Still pulling to the left a bit)
  • Play with cup distribution valve (Going to put it on an MOT brake tester and adjust the valve)
  • New exhaust (BTM baby ;))
  • Blank rear holes in boot floor
  • Air vents in rear windows
  • Increase cooling capacity
  • Check engine after engine temp
  • Heat shield gear lever
  • Cut front bumper and cross member for more airflow
  • Trim wheel arches at front for tyre clearence
  • Add Castor
  • Flare rear arches
It's not the above list thats the issue really as I can sort all that in time its just the money in doing so but I will certainly be trying my hardest as always :)
Pit stop practice wouldn't be a bad idea lol would help if I didn't stand about lol
You did stand about for quite some time, Lol. And then had a little chat when back in the car
Haha lol! I was just a tad worried but Freds "F**K off out of here and drive" put my mind at rest :D
Flol, good work mate, Comintment and no fear. Bet Lisa in the Puma pissed her knicks laughing watching that
hahaha at the vid! - too much looking behind you there mate, not enough looking forward
I did the same thing loads when I was last at Donington - that bloody first corner, I spent more time in the sand than I did hitting an apex :(
Regarding increasing the cooling mate - a lad on here has just found a £160 ish golf alloy rad on ebay - it's the same height as the polo one but longer and apparently offers 30% better cooling being all alloy
I'm gonna order one for mine in a few weeks as the Polo rad really does struggle :(
Haha I was trying my bestist boss ;) Yes probably!
Lol yes probably but the Proton was better on the brakes and thought he was going to come back round the outside so didn't want to run deep and take him out lol!
Yes I saw Mark (Iceman) had put that link up but I don't know how much bigger I need to go as it was running mega hot!
*you think it was running mega hot ;)
That is very true! Need to work out if its the sensor, If I boil a kettle and then put the end of the sensor into the water would that work? lol!
Think that Proton needs a rising sun scheme.....
Because kamikaze pilot
Just change it if not sure its working right
My bad :o
[video=youtube_share;8Oy36wI20-4]http://youtu.be/8Oy36wI20-4[/video]
Girls slide ;), see if Jay can find my qualifying one at the same corner.....I ran out of lock.LOL.
Awesome result mate, well done, about time you got a break!
Thanks Kenny, Yes finally but things are looking up now and sure I can leave the past behind and have a smoother run from here :)
Haha lol I don't know if it was junior or senior Cassar in the car!
Where could I get a spare that would go in the same place? :)
what sensor? ECU coolant temp one? they're about £15
nope, but i'm pretty sure James doesn't have the stock sensor in place
Yes Dan ECU coolant temp one :) I will be taking a photo later when I go down to the garage so will post up! Thanks
That looks like the one Dan :) Will whizz mine out and check the size but thanks!
if it's in the stock sensor position, then that's the one.
When will the vid be up James? I feel like a kid 'are we there yet'.
