Thanks mate yeah will take a few weeks to sort but will speak with gripper first and see what they say.Still space a rockingham on the 20th of this month James, but at a guess would be pushing for that too,
Be good to see you though if your not doing anything that day, you can make the tea!
Thats bad news about the gear box mate
No AST's yet, were supposed to be here Thursday gone,
Its given me the time to wire all my Race technology stuff in, feels like I'm back at school with all the learning of the software, Programing, then re programing, programing again, then re programing. lol
Car was all sorted running and drive really well, started doing the geo but then noticed the rebuilt gearbox leaking oil from the join in the casings! Going to monitor it but Bedford is off the cards as can't get the gearbox out, fixed and back in
going to do Brands in a few weeks instead.
Sorry mate must of forgotten to replyThat's a bummer James! Whens Brands, might pop down if i'm off work. (live 10 min from Brands).
Yes I'm sure it won't be too long before it's next tripBe seeing this up at RS anytime soon?![]()
Good to hear, look forward to seeing it!Yes I'm sure it won't be too long before it's next tripgoing to play around with a few bits on the current engine and also the new engine will be getting built this year so hopefully see you up there at some point
Great news mate! They are such good little carsGood to hear, look forward to seeing it!
I'm on the lookout for a 182 now so may well be on here some more![]()
With you race guys , what camber and tracking settings do you use ?
I run 1mm toe out each side and 2.5 neg camber front, 2 neg camber and parallel toe rear - well will be parallel once I get a 30' min shim for the O\S\R.
Though what's good for one isn't good for another - adjust push on and re adjust is how I came to my settings.
Pete have you ever checked your front tyre temps? I had 3 deg neg at the weekend and the shoulders were boiling. First time I have checked with a temp gauge.
Inner or outer shoulders?
No - what were your temps?
Outer shoulders on Yoko A048-r i.e not enough camber. I run 10min toe out but that won't cause this difference. It was circa 10 deg inside and circa 40 deg outside. Going for a lot more camber this weekend and see what happens.
I ran a fud hair off of 5 deg with my RSR's and still had tyre wear with sportlines fitted. Its inevatable with them tyres IMO, they have a sidewall that folds over.
This new car has coilovers and corners a lot flatter so I didn't think I would need as much. Yoko or the teams that run them say 5 deg max although as small as possible if the car is on 'proper' coilovers and the correct roll stiffness.
That temps I have are a bit low but the important bit is the difference, the inside edge should be the hottest part of the tyre if correct which was the opposite on mine.
that's very low camber pete! I'd have assumed you'd be knocking on for -4deg!
Anyone else have recommendations for camber and tracking , want to get it done tomorrow
cheers Ian
Toe out on the rear will induce more oversteer but I prefer to get the balance with the damping adjustment and spring rate as toe out on the rear in the wet makes for some very lively action!
Josh cook ran loads of toe out on his cup racer for exmaple IIRC
Yes, but he stated that it was a handful and not for the nervous (and done out of wanting a fast set up but knew it was on the edge) - and he also came off on the warm up lap at Brands last year as the car was a hand full.
Hope you enjoy getting some use out of it now its ready to rock and roll![]()
