RB 182
Love the bonnet, I think the whole car should have a similar scheme. It does look very polished and perfect for a race car though ![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Oooo the hose i'm going with has an I.D of 8.7mm I wonder if I will get away with it?!
Thanks mate I have seen too many fuel fires before to scrimp and save on this bit of the re-build
Thanks MikeLove the bonnet, I think the whole car should have a similar scheme. It does look very polished and perfect for a race car though![]()
Yes I think that is just a shade under 8mm so is probably the perfect size! If I can't make the -6 pipe work then I will do a little in 5/16's and then get an adapter to go to the thicker boreI used 5/16" hose. So far, so good!
I think sprayshack will be putting some photos on here tomorrowlol can't wait to see this bonnet now
No point other than a safe connectionWhat's the point in going upto thicker bore AFTER a restriction?
just stick at 5/16 and get a swirlpot to suit
Mine wasn't BTB mate lol! I was told it was BTB by TDF but it was just a K-tec exhaust that fit really badly and had the tailpipes chopped off for the *BTCC sliding tailpipes* (Read Halfords tailpipe trims)
I have seen BTB's work mate and it is very good indeed! For me though it had to be single back box for weight so hence the idea of BTB making one specially
Yes crazy isn't it matewhen he told me this over dinner I was shocked.... one of the worst stories I have heard in my MANY years around modded cars... sadly for James... it was just another small part of a truely horrific horror story.
Sad... coz honestly James is one of the nicest people I have EVER met and is a SUPER generous and trusting guy.... who can REALLY REALLY pedal!
Personally mate... but the car away. I can store it safely for you as long as you want,
Go abroad WITH your girlfriend and take the job who have been offered.
You had a go at racing and the donno race was one of the best things I have ever seen! AMAZING!
but real life takes priority.
Take a breather from the car mate. Sort your work life out and come back to it. Work HAS to come first!
Trust me I'm old and semi sensible!
Haha yes mate anytime you wantIn the meantime we can use the trailer to track blo0dDiamond! Anglesey?! Using your tyres obviously as ours are s**t
Weekend away, get a few together, what say you Yorkshire?
Very jealous TonyLOL, I just plugged the battery charger in today, 1st time I've looked under the car cover since Oulton.
Does anyone one know which pins on the fuel pump are + and - as there are 4 and I don't want to put 12v through the sensor for obvious reasons
I need to drain the tank as it's nearly full and need to then drop the tank before rolling the car to work on the underside
Ha, I haven't started yet, fancy doing a track day before it all comes apart.
Sounds like a good idea! Stop making me jealous haha, I was saying earlier I would of probably done one in mine if the engine hadn't gone! Was nice just to drive the car and not have to touch the toolsHa, I haven't started yet, fancy doing a track day before it all comes apart.
Haha that sounds like more effort than just dropping the tank full lol!Syphon you big girl....bet you spit too....
His battery might not be charged in time :rasp:Tues ...Brands...or are you a girl too?
How much, with who??
Mmm, I'll see.easytrack...though the price is now 169.....as it's only 2 days away I guess....was 139 not so long ago.
That is a good point actually Mark! Mmm where is there a bottom pipe?I drained my tank before dropping. I was worried it would distort as I undid the bolts as it had so much fuel in it.
Couldn't get a pipe in there due to the anti siphon stuff had to remove the bottom hose hold the flap open with a screw driver with a bucket underneath it lol.
I was covered in fuel by the end of it.
Somebody :headno: decided to weld a roll cage over it so it can't be removed without dropping the tank lol!If you dont want to syphon it, take the pump out and use one of those pipes with a valve in from Halfords, just shake it up and down to start it off.
Yeah tell me about it! I just find all this stuff funny nowFFS & lols...
Mmm, I'll see.
Say's fully booked.
The main hoop is further back in my car and the straight bar that runs along the rear squab area is directly above the fuel pump area, I could probably break the pump and then get it round but dont fancy doing that lol! I will just go and try with some bits of wire and a battery on the connectorPMSL!!!! What's in the way? bars or flat plates?
