Yea brembos look good in redI think they should be red with them being Brembos, although the silver paint work on them is top notch at the moment isn't it Dan :wink:
Thanks Tom! I'll be keeping them silver for the time being. My Hammerite has gone off so they look horrible and matt but it'll be sorted at a later date haha.Looks awesome mate, are you getting the calipers powder coated? Or keeping them silver?
Use a string line to get the wheel alignment near enough to drive it about Dan:up:
Amazing work Dan.
You should be proud, you've made a great project car :smile:
I'm running a pedal box Peter!
Sorry mate, I miss understood the first bit! Cheers dude. Open both bleed nipples on the same caliper I assume?Alright, still do what I tell you! [emoji1306][emoji1306]
Annnndd? How was it?Went for a drive and didn't die.
Loud. Rattly. HahahaAnnnndd? How was it?
And the results are.....
BANG!And the results are.....
Chris was only getting started at 4pm@dann2707 ???????
Just mapping now. Had an issue with a brand new injector not idling correctly. Working fine at full power. No power runs as of yet. Just sorting out other things... As you can tell I have no idea about mapping haha.
Original map on there needed a lot of fettling.
Yeh its at efiGone to efi?
Nope, safe map with very little boost. Over to you @dann2707Best place. Awaits results :smile:
Power wise 259.5679 ish
