There has been a massive amount of changes over the past month, with the above being just one. Days have been spent stripping l excess wiring out of the engine and interior looms, then rewrapping everything and generally tidying things up. This saved a good 4-5kg which I could not believe - there is so much rubbish in there. You always think these are going to be 'quick' jobs but they are so time consuming. The cooling fan has also been re-wired so the ECU controls the relay, rather than a radiator switch, and a manual override added.
With the rear end components replaced, I obviously needed to get the alignment done again. I decided to ditch the current 'normal' tyres I use for wet days (RainSport2) for a set of Michelin Pilot Sport 3's. Still using the Federal RS-R on my other set of wheels for dry days.
Once those were sorted, I had the alignment done. Previously, I ran:
Camber - 2.3deg Front, 1.8deg Rear
Toe - 0 Square Front, Total 20' Toe In Rear
I have now changed this, increased camber and a tad more rear toe:
Camber - 3.1deg Front, 2.4deg Rear
Toe - 0 Square Front, Total 30' Toe In Rear
The rear is now around the 'stock' M3 3.2 spec, alignment wise with camber and toe. I will have to see how it feels and go from there - the additional poly bushes on the rear arms are noticeably different.
Next up was a change in gearbox mounts - the standard ones do not last long and go soft over time. There are a number of companies selling poly mounts, but I wanted to avoid the 'bolt through the middle' style as no doubt it would just drastically increase noise and vibration. Quite a number of people use the
RevShift mounts, which are made by a small company in the US. I ordered a pair and a couple of weeks later they dropped through the letterbox..
They were then fitted, and I also changed the gearbox oil at the same time. My gearbox has been noisy for some time, and the oil has already been changed (75w90) around 12 months ago. I suspected the level may have been low, or it just wasn't thick enough, even though its the recommended grade. Since using the single mass flywheel I have also had gearbox 'chatter/rattle' on idle, which goes once you are moving, but it was annoying. Many people have had success with mixing RedLine oils, but the two I needed are not really readily available. I went for the Lightweight Shockproof instead...
Luckily this seems to have had a great effect, as shifts are now 100x smoother and 90% of the noise has gone.
With the track day at Spa fast approaching I had a list of things that needed sorting, as I had been putting them off all year. With one of the requirements being a fire extinguisher, I debated for some time about what to do. Hand held would be sufficient, but you still have to unclip it, take the pin out and then use it, all whilst trying to get out of the car over the cage, etc. With having the cage, and getting out being the highest priority in case of fire I wanted something a bit more substantial.
I ended up opting for a plumbed in system, went with OMP over Lifeline but either would have sufficed. I also wanted to have the electrical system isolated, as if the fire was actually started by an electrical fault in the event of a crash the extinguisher would be useless. This ended up being a massive time consuming job. I already had most of the inlet system removed from the engine at the time as the loom was being trimmed - which gave good access to sort some bulkhead fittings for battery cables / extinguisher piping.
The next problem was mounting two pull cables on the outside, as the bonnet comes right up to the windscreen on the E36. I got a bit creative with the 'vents' in the top of the bonnet, and notched them out so the pull handles would go through. Mounting bracket was then made, and cables passed through to the inside via the scuttle panel using a grommet.
Two nozzles were put in the engine bay and piped up (exhaust and inlet side), you can just about see them on each suspension turret. The pipework runs round the back of the engine in the same mounts as the brake line. Two were also fitted inside, one in each footwell.
On another note, the whole exhaust side of the chassis, bulkhead and part of the tunnel have had reflective tape installed to try and keep some of the heat out of the cabin when on track. You can just about see some of this on the above picture.
The extinguisher bottle was mounted behind the passenger seat, and pipework ran down the passenger side of the tunnel.
With that installed, I needed a pull handle inside to activate it if required. I also needed to mount the battery isolator, to which the exterior pull would connect. I had been meaning to move my gauges for some time, as the wideband used to be in the top centre vent, and the oil pressure/temperature in the middle of the clocks. I ditched the radio and made a panel to house them both on the dash, then mounted the isolator next to it. Swapped the clocks out and now I only have an aftermarket water temperature gauge in there.
At the same time, I replaced the standard OBC at the bottom of the centre console, which I had re-worked previously to use for the data logger. I now have a single switch for the data logger, so added some additional toggles for the radiator fan override, rear video camera power, etc. A bracket was made for the battery isolator pull cable and mounted to the dash - then a bracket was made for the extinguisher pull handle and that was mounted at the very bottom.
It all looks relatively simple, but making brackets, mounting things, is stupidly time consuming when doing a proper job of it. Obviously the extinguisher locking pin will remain in place when not out on a circuit.
Some other small jobs have also been done, like re-making the front brake ducts/mounts, moving charging points and adding new connectors to wiring, but never got any pictures of that. After a good month of messing about its pretty much ready for Spa, bar needing a quick clean.
More soon...
