JamesBryan
630! Wow seems high that doesnt it??
The Cup racers were close to 1000lb rears
That is what AST recommended for me.. But being old my reflexes arent capable of a twitchy rear end so i choose 90/90. But in saying that i have been suffering a little understeer , which after having a conversation with Simon at the Autosports show in January, i've now been experimenting with raising the rear ride height slightly , increased my rear tyre pressure 2 psi above the front, 2 clicks higher on the rear dampers than the front and im pretty happy with the adjustments im making.. The idea of the harder rear is to help keep the weight over the front axle and rotate the rear ,(but you probably already know that) In hindsight i should have trusted AST'S advice and gone with 90/110..AST standard track setup is 90N front, 110N rear which is 500lb and 600lb.
Sent from my SM-G977B using Tapatalk
My car last weighed (last year) was 980kg with half a tank.. So I'm probably roughly the same.. On track I'm now running A048 or R888r ( Track/weather dependent) at 30psi front 32psi rear hot .. 7 clicks front 9 clicks rear.. I find that setup to be very stable and some people say that have followed me that my car looks planted..I cant comment on having cold semi slicks on the back but mine is not twitchy at all. The whole car becomes loose near the limit not just the rear or front.. (Private roads)
Granted Im 1060kg half tank of fuel with me. But I think Im 6-7 clicks from soft on the rears, if I went to 2 clicks say it would be like a boat. Front Im 4 from soft but thats road setting as bumps are no fun after that, Ive set the fronts to max once, darty is an understatement! This is why I want some valve changes done on the fronts..
Why are your rears higher pressure than your fronts when the rear is lighter?My car last weighed (last year) was 980kg with half a tank.. So I'm probably roughly the same.. On track I'm now running A048 or R888r ( Track/weather dependent) at 30psi front 32psi rear hot .. 7 clicks front 9 clicks rear.. I find that setup to be very stable and some people say that have followed me that my car looks planted..
Edit: my car is lighter than yours..haha[emoji23]
After taking on board some advise from both Polleysports and Simon, both suggested by running a slighty high pressure on the rear would help my particular situation, as in to help rotate the car and dial out my understeer..Why are your rears higher pressure than your fronts when the rear is lighter?
Exactly this.. and it appears to be working.Gets the rear a bit more mobile.
You want it rotating on the limit to kill the understeer.
Race proven.
In the wet you'll want to revert to a more neutral balance, unless you're a god driver.
Behave.Wont your rear tyres over heat in the centres?
Behave.
Camber and toe will also effect the way the tyre heats up mate. You need a tyre probe to monitor temps to tweak the setup properly.![]()
Ive bought this to have a play withSorry dad, I was thinking about next trackday I'm going to take the thermal laser from work with me so I can see what the crack is.
In the wet ive been dialing everything down to as soft as poss with the emphasis of getting more grip to the arse end..Race proven.
Gives you an idea though doesnt itIR thermometer will only tell you surface temps.
I use the Longacre pyrometer, it's not cheap but it gives accurate temps quick.
What wets do you all run??
I've been using Uniroyal RS3.. And they seem to be quite good as long as there is standing water. As soon as a dry line appears they overheat really quickly. I just pull in and swap to R888r on those damp days.What wets do you all run??
What do you think to them. They are pricey arent they?Toyo R1R
Are they wets?Ilya (pule333) ran yoko A052 last time we were out at Bedford in the torrential rain and they seemed alright.. Although he did drive my car with RS3 on and said my car felt more stable than his..
Why?You cant use this Eddie
Why?
Well no they're not.. But I was at Brands on a very wet day and some honda drivers that race in a Tintop series were using them and said how good they were in the wet, so thats why Ilya tried them. TBF they weren't bad.. You know his car and how mental Ilya is and he was doing ok on them..Are they wets?
CEE U NEXT Tuesday M8..[emoji1787][emoji1787]Because it says professional instrument on the box.
Professional idiot that's as far as you go with the word professional [emoji1787][emoji1787]
Best send it back m8
Found them at 44.50 each at the minute which drops them down to RS5 price rangeNot as good as Rainsports on the absolute wet, but then they're better in drying conditions.
Around £70 ish a tyre I think.
You been drinking ? Your loaded you should buy me some for the second set of shiney black 2118'sGetting rarer now they're discontinued.
Get me some![]()
