DC2 TypeR / E36 328i
Home now, those rear pads look fucked - did you end up changing them?
So what benefits do you think you'll get from the new top mounts?
dan
How much do they cost bud?
wow!
i've not heard of that happening before.
Why did you choose to fit the mounts at the 5,6,7 o'clock position? Got mine fitted at a motorsport garage and they said it was far more beneficial to fit them 6,7,8 o'clock on the drivers side and 4,5,6 o'clock on the passenger side. Said it was for better castor adjustment as the kw's has good camber adjustment anyway.
They look damn good in the engine bay dont they!
Great work mate, fancy sorting me out with the old ones? I wouldn't mind giving them a go.
As for the knocking, when is it? I'm going to suggest balljoints?
Oh and a question: what spacers are you running? Ta.
they look sweet in! got mine yesterday maybe get out tomorrow and get them on! although one thing i am jelous about is...your bottom bit is orange, mine is just blackhaha
all changed a bit since i last saw it mate! AST top mounts FTW, mine need setting back up again, got the caster in two different positions currently
Chrudat, apart from that you've got it just right.
Wheels, perfect, cup spoiler, perfect, lows, perfect, have a full geometry on it and do the dash, nothing else needed.
Love the way this car looks, love the mechanical upgrades.
Its what mine would be if I had the money
Good work mate
Track rod ends eh??
Something I've never done.
What size balljoints did you buy? The 12mm or the 10mm??
12mm are your friend Rob, They come about 8mm out of the hub and then will take another 30 minutes to remove the rest of them!! pain in the ass job!
Looks great Nickson, I have set mine to full caster and used the camber bolts to adjust the camber, give that a go it may solve your problem.
James
I've done balljoints before, just making sure he put the right size ones in, otherwise they knock.
I know nothing about track rod ends, but I will be changing those now![]()
I have exactly the same issue with my AST's! I may ring Curtis and see if he has an improved bolt setup now as I saw some at JMS with a different bolt setup.
i had the same problem when i bought 20mm spacers, i sent them back and got 25's instead.
also thought about painting the spacers? i think they would look better black![]()
yeah i dont like the look of seeing spacers behind the wheel.
nah with the bolts being longer than the spacers the wheel was never fully tight
First - Ewwwww!
Second - Wtf are the looms for? Seriously?
Ph1 lights ftw!!
