NorthloopCup
		Weld ftw!Nothing a bit of sophistication & filler won't sort out lol
Weld ftw!
Nothing that wouldn't balance out mate.Liquid metal is the sophisticated stuff [emoji6] . Not sure if it will affect weight in any way though .
Brand newDid you buy the bias valve new
Not all the screw types can reduce the pressure enough mate. I'm sure it's a tilton one that reduces the flow enough though.Brand new
Explains why the tilton ones are double the priceNot all the screw types can reduce the pressure enough mate. I'm sure it's a tilton one that reduces the flow enough though.
Buy cheap buy twice though I suppose. You need to read up on the specs to be 100% sure that it will do what you need.Explains why the tilton ones are double the price
@Ph1 Tom did something similar to this and was successful.Yep £100 [emoji16] gonna buy some ford pressure reducers and remove the compensator valve, then see how that goes... If not I'll remove the OBP and replace with a tilton one I think...
I've just looked at the specs for the tilton and the performance is the same on a lever type or the screw type.Interesting! hopefully he can inform more!
@Ph1 Tom did something similar to this and was successful.[/QUO
I have a wilwood bias valve and apparently it reduces pressure from 50% and adjustable between 100psi - 1000psi.
More research needed me thinks.
How bad is it whilst driving. What pads are you running on rear
what bias valve you using?Not sure then. I'll plumbed mine in so
I'll let you know once it's back on its wheels
Wilwood. But I would say it's similar to yours. Apparently it does 0-57% and from 100-1000 psi.
Let me know how you get on once the Wilwood is fittedSo Fuel tank back in, rear axle, etc etc
So last job to sort was the brakes, lines made, brakes bled, car down and wheels torqued up.
Excitedly took it for a drive, put my foot on the brakes hard... STILL LOCKING UP ON THE REARS [emoji36] [emoji36] [emoji36] [emoji36] [emoji36] [emoji36] [emoji35] [emoji35]
Sooooooo.... I put two reducers inline and still nothing tbh, made no difference really at all!
This looks like I will be ordering a Wilwood brake bias asap.
it will lock if handbrake is connected or not,I think you're looking in the wrong direction with the hydraulic side of the rear brakes
If the rear wheels only recorded 28kgf on the MoT (presumably not locking) there's no way they should be locking when driving,
I would be looking at how the cars load transfer is either drastically unloading the rear axle and the rear wheels are genuinely only
needing 28kgf to lock, Or
how the handbrake cables are routed and pulling the cables tight as the axle drops away from the body easing the brake on,
Is the rear axle running lots of negative camber and the tyres are running on a very narrow band of the inside edge, did the tyre fitter put 50 psi in the rear tyres because he was to busy texting his mate?
I thought you'd done away with the rear compensator??it will lock if handbrake is connected or not,
The tyre pressure are good and not s**t tyres direzzas.
I've had 2 sets of suspension on the car and it has been doing the same thing over both (ghas and asts)
I have changed the height of the car around varying different levels of rake and lower on the rear.
Do you reckon the rear brake lines coming out of one port is causing to much pressure being exerted on the rear lines?
But I know what you mean as I think on the last MOT is was pulling 14kg, so could the rear compensator be f**king it up?
Nope i was gonna try the rear reducers in first then go from there [emoji16]I thought you'd done away with the rear compensator??
Well I'd quite confidently say there is your issue mate. Either pipe up the compensator valve correctly and try again, or remove it and try the reducers.Nope i was gonna try the rear reducers in first then go from there [emoji16]
The compensator valve is piped up correctly mate.Well I'd quite confidently say there is your issue mate. Either pipe up the compensator valve correctly and try again, or remove it and try the reducers.
