Tomotek
Now I'm finally up to date on the build I can share some pics from its first outing!, all this work happened mid august in anticipation for a shakedown we'd booked at Blyton Park.
All very last minute, so a setup was thrown at the car, toes, cambers, start tyre pressures, ride heights etc.
@Jenbo and I headed up to Blyton for a day that had been booked with quite a few of our friends. We planned on using the day to check over the car, ensure everything was working as it should. We needed to check the brakes, setup the bias adjustor, bed in the brakes, ensure the rad cooling was sufficient, bolt check everything, bed in the new wheels and studs etc.
We chose Blyton as it's local to our friends, nice chilled environment, good track and not much to hit if something goes wrong.
I strapped the car on the trailer and headed up!, I was treated by some pretty nice weather!.
Family wagon got us all up there nice and easy
Setup the awning and got unpacked
@Jenbo getting those wheels torqued
All ready to go to run under its own power!.. big moment!.. Ben let me do the honours of taking it for its first few laps.
Couple of external clips capturing the big moment!..
Few pics from the rest of the day...
Chasing @chrispyclio in the TDC mini
Good first test for the car. Quick straight out the box!, no mechanical problems, engine pulled well, cooling worked perfectly.. only real thing we had to do was drop the tyre pressures and tighten up a slightly loose front damper top mount.. all in all a great first drive in the car!.. we weren't really timing but we got clocked doing low 1:17s on the Outer circuit
We then packed up and got the car home. Ben and I had a bit of a de brief and noted down all our thoughts for the day to help us improve the car going forward.. Now we were just eager to set it up properly and go back out again for a first proper track day!.
