I'll be honest, the plan was to get a load of pictures putting the lightend flywheel, clutch and box on. Then on the hoist ready to drop in but trying to rein back 3 helpers making sure all bolts were torqued to spec and nothing was being over looked or missed whilst trying not to damage my fresh paintwork was exhausting!! Bloody animals!
It probably took 2 hours in total trying to be careful to build it up and drop it back in with zero damage but we go there in the end.
Once it was in and secure I made the brews and some food then thanked them and sent them on their way. I couldnt cope anymore. It was like looking after 3 kids all asking wheres the nut for this, wheres the nut for that, whose got the 13mm whose got this whose got that
I would mind but I had set everything out with all the parts necessary prior to them turning up to make it easy!!
Anyway once they had gone I set about linking the coolant pipes up, wiring up and anything that I could do before putting the bodies back on.
At that stage I was going to pack up for the day and enjoy the sun but then I figured let's get it running first.
So rad back in, main part of the bodies on, I put some Redline MT90 oil in the gearbox through the wet side drive shaft hole so with the drag from the engine it wouldnt spin dry.
Threw some cheap engine oil in as I wasnt 100% sure there wasnt any grit from blasting in there, this was going to be basically run it up to temp leave it on idle for an hour and then drop it back out, change the filter and then put Millers motorsport proper oil in. But for now it was fine just to start it. Ran a brand new throttle cable to the bodies.
Filled the coolant with just water as I wanted to flush the system anyway and then gave it a crank to see if it would start. It wouldnt, after a little investigation I had left the crank sensor unplugged
Plugged it in and hey presto!!
Taking shape nicely, happy with how everything has turned out so far.
