182 Titanium Yorkshire B Road Project
Rskennedy
  Clio 182
Hi All,
As some of you may have seen in the intro thread. I have recently bought a 2005 clio 182 non cup in black gold. Its got 83k on the clock and the belts were done at 78k according to the invoices, so I should be in good stead. It spent most of its life in the Orkney Islands before ending up in Essex for the past 5 years original plate was YF05YHO not sure if it was anyones on here?
I had a 2004 clio 1.2 as my first car so have a sentimental attachment to phase 2 clios! I have just come from a 595 abarth competizione with all the trimmings as my weekend fun car, being in the Yorkshire Dales having a small car for B roads is great fun on the weekend when theres not cow s**t everywhere.
Pic of the Abarth - As a comparison the clio feels sharper and faster without all the lag from the turbos. Everyone goes on about how s**t the seating position is in a clio....drive an abarth!
Car came as standard but with a stainless exhaust system and sports cat, looks like either Pure / Ktec but it has no branding that I can see. Its a bit...loud.
Bad Bits
I have a knock coming from the rear drivers side, you can feel its loose when you rock the wheel stationary
Powersteering doesn't seem to be working at a stand still
Belt whine (could be something to do with power steering)
2nd gear sounds a bit rattly, but that might just be the resonance of the exhaust
Missing the front splitter
Paint is swirly and has a lot of badly touched up scuffs
Interior is grim, sticky buttons, gross seatbelts, badly tinted rear windows, generally gross
Drivers seat has a bit of play
First thing I did was get the 182 wheels off and swapped them for some 15x6.5 Turinis ET38 (I think) wrapped in Michelin PS3's 205/50/15 and its already transformed the handling.
Car is headed to the garage tomorrow for a once over (I am not good with a spanner, I drilled through my own finger putting my number plates on...). So I will update the thread with the outcome of that.
Rskennedy
  Clio 182
@Andy P I spent the past 3 days reading your thread and I am promising myself I won't get as carried away as you... but claude makes a convincing argument to spaff all my cash...
mumpy
  Clio II RS 172
Hi All,
Bad Bits
View attachment 1729209View attachment 1729210View attachment 1729211View attachment 1729212View attachment 1729213
Nice car mate! Enjoy!
Btw whats with the suspension? Seems to be sitting pretty high.
bowen86
Does seem really high and those rear shocks look, unfamiliar?
Nice clean base to start from.
Rskennedy
  Clio 182
Cheers everyone
Rear dampers are some cheapo OEM copy ones and springs look stock too. 15” wheels obviously add to the monster truck vibes.
I will eventually move to coilovers once I get stuck into it. I do like the way it rides over the bumps at the moment though. One of my big gripes with the abarth were the stock bilstein shocks were sooo crashy, rattle your teeth out.
gudger12345
  Ph1 172
Welcome
I have removed the complete Power steering set up off my ph1 if you need any parts as am going epas.
also getting another 172 (Boosted) to either return to standard or break if you need any bits
it does have some tasty mods
Also i am located in the North east
Rskennedy
  Clio 182
Welcome
Lovely, yeah mate please drop me a message with any of the mods. I am definitely in the market to start stockpiling stuff.... so it begins!
Rskennedy
  Clio 182
Garage Check Over Update
Been in today and had a good check over and the good news is they said its very clean, no rust and no major issues. Power steering is apparently fine I am probably just used to the EPAS in my Volvo XC60 daily. Clutch is also fine, I just clearly can't drive.
Problems are:
  • Throttle pedal needs replacing
  • 2 wheel bearings need replacing
  • Headlight washers not working - Will be replacing with blanks anyway
  • Rear wiper motor is dead - not really bothered about it may remove and blank it off
Very happy to have a clean bill of health apart from these little niggles.
Next Jobs beyond these:
  • Get a spare steering wheel to get re-trimmed by royal
  • Missing the splitter - I will order a ktec/skoda fabia one
  • Strip out the rear, sound deadening and carpet, possibly a K-brace or strut brace
  • Its booked in to get a full detail and paint sorted at the end of march
  • Enjoy over the summer and see what breaks along the way!
  • Full service and replace all fluids when the MOT is due in September
Long term plan is replace anything that breaks with something uprated.
Mr Underhill
Problems are:
The chaps at @FrogJam Motorsport can help with wheel bearings, and fitting if you so wish. Also, North East lads. They have a website here https://frogjammotorsport.co.uk/
Rskennedy
  Clio 182
Todays odds and jobs whilst it was a rare sunny day. Sorry all boring updates today.
Had a wobbly seat so pulled away the sides and tightened up a couple of very loose bolts which has done the trick
Then set about sorting out the DISGUSTING seat belts
Then set about solving a rattle in the boot. Loose trim was the culprit but discovered someone had snapped all the clips previously so I doubt that’s going back together
Whilst in the boot I found why my rear wiper wasn’t working… it was unplugged. Plugged it in and HEY PRESTO! It worked, but I couldn’t turn it off… so that explains why someone unplugged it. Any ideas?
bowen86
Had the same boot trim rattle and the clips were snapped not the actual fixings like yours. Looks like you'll need a new boot trim, fairly easy to get hold of and the clips are on ebay too.
Lovely updates, cleaning the seat belts. How's the plastic trims? Gooey?
Rskennedy
  Clio 182
yeah I’m sure there’s plenty boot trims out there. I’ll share some pics of the belts when they dry out. Might need a second bath…
Plastic is a gross sticky mess. I’m going to leave that to my detailer in March and put up with it for now.
Got number plate light and side indicators to replace when they turn up next. Then swapping the throttle pedal and getting the wheel bearings sorted.
Rskennedy
  Clio 182
So! I’ve been offered a fully renovated silver 182 from someone on here which pretty much ticks all my boxes. So debating selling this one and purchasing that.
Anyone in the market for an 84k mile BG ff? Would take what I paid for it on the original 182 wheels £4250.
Rskennedy
  Clio 182
After the worlds shortest 182 ownership of 10 days…
The black gold was sold last weekend and I picked up a titanium 182 that had been well loved and had a lot of the things I had planned to do, already done. Rather than start a new thread I’ll just continue here.
Massive spec list I’ll put here
Exterior:
Front carbon fog surrounds
Carbon front splitter
Carbon bonnet if wanted
Carbon washer blanks
Carbon bumper inserts
Carbon wiper blank with custom french flag
Speedline turnis freshly painted with brand new nankang ns2rs tyres all around
Carbon door bullets
Led lights front and back
New genuine front grills
Cup spoiler
Rear tinted windows
Suspension & brakes
New cup shocks and cook sport springs
Pms wishbones with welded strength plates
Pms bump stop steer - NEED TO FIT
Powder coated rear axel
Pms rear axel strength plates welded
Pms stub axel kit
Brand new track rods
1.5degrees camber shims rear
Eibach front camber bolts 1.75 degrees camber
Black series powerflex bushes fitted to front and back
Purple power flex front anti roll bar Bush
Rear Whiteline anti roll bar
Megane 225 brembo conversion kit painted in blue and fully refurbished
Brembo HC Front dics changed in 2023
Brembo HC Rear discs and bearings brand new
PBS Pro race front brake pads
Ds2500 rear brake pads
Castrol srf brake fluid
Geo setup from Harvey Motosport
Hel braided brake lines front
Full Custom rear braided brake lines
All new rear hand brake cables
Stud conversion 65mm
10mm front spacers
New abs rings
Engine and components
Cam belt and water pump done 2021 by mendip autos
Engine painted black
New lamba sensor
New crank sensor
New map sensor
New genuine fuel injectors
New genuine ht leads
New genuine coilpack
New ktec racing inlet gaskets top and bottom
Inlet manifolds ported and polished
Gloss black fuel rail and inlet manifolds
Throttle body gas flowed all done by MS custome
Gearbox refurbished by select motosport 2021
Gearbox powder coated in silver
Brand new luk clutch
Millers Gearbox oil changed every year
Millers nano drive Engine oil just been changed
New genuine pollen
Power flex dog bone mounts
Evol Gearbox mounts
Powerflex Engine mount insert
New Engine mount bracket
Brand new coolent bottle
Brand new JMRS blue coolant hoses
Brand new jmrs induction kit
Direzzen alloy radiator
Powder coated Engine mounts
Powder coated Gearbox mounts
Brand new bosch battery
Cup alternator setup and air con delete
c fab battery cover
Cfab map sensor braket
Cfab ecu braket
Gloss black ecu cover
Pms Carbon fibre shifter
Custom metal Engine heat shield
Carbon fibre engine cover
Ktec decat
Ktec supersprint exhaust with custom hangers
Remapped by EFI running 189bhp wheels and 208bhp crank
Interior
Flocked dash,
Black Alcantar headliner
Black Alcantar A pillers
Renault sport floor mats
Ktec blue boot mat
Blue k brace
Led lights and cup front interior light
Pms shifter
Ktec Renault sport steering wheel
centre console destickyd
Jonfos lower seat mounts
Corbeau bucket seats
New steering angle sensor
Mega carbon dash trims with blue reanult sport.
Carbon door handles
Carbon door pulls
Carbon hazard surround
Rskennedy
  Clio 182
Loving the car, it’s so so good.
After driving to Manchester airport and back and being absolutely deaf by the time I got there decided to fit some sound deadening to relieve some of the noise.
Great success and has made the car much more liveable.
Had a weird immobiliser thing where it flashed (key not recognised) but left it 30 seconds locked and unlocked and appears to have solved it 🤞
Ktec sports cat ordered ready for the MOT and to further tame the noise and fit PMS bump steers whilst I’m at it.
Next up after that is trying to resolve the PMS shifter rattle. I’ve got plenty of sound deadening left so may wrap that around the linkage instead of filling it to see if that can solve it.
Rskennedy
  Clio 182
Car is back with a pass for the MOT!
Ended up buying a Ktec Sports Cat which was no issue on the emissions and has transformed how liveable the car is. So much quieter and a bit less embarrassing.
Tester did turn a blind eye to the airbag light being on, but probably need to get that sorted (corbeau seats the cause i guess)
Also advisories for a corroded sill (next winters job)
The more worrying "O/S/F INPUT SEAL SLIGHT LEAK" - anyone any indication what that is? I picked it up in a rush last night and didn't get chance to speak to anyone.
PS. How can I change the title of this thread?
Darren S
If you message one of the mods (people with green names) - they can change it for you.
Rskennedy
  Clio 182
After passing the MOT and having a good look over. Had a great Sunday drive out that resulted in a 6 hour wait on the moors for the RAC.
Driving along, misfire and then dropped a cylinder, no engine light, no other lights on the dash other than service and airbag.
Sounds like a bag of spanners anyone any ideas? I’m thinking slipped timing but it has had a cambelt change and should throw an engine light? Blown a spark plug out the block? Has a carbon engine cover on and I didn’t have any tools with me and it’s now pitch black so not managed to investigate that.
Mr Underhill
When I changed my injectors, I hadn’t pushed one of the connectors on properly - usually hear a click - and it sounded exactly like that. Pushed it on properly and it was perfect. So as a complete internet guess maybe faulty injector, although no engine light suggests it might be ignition related. Replace all 4 if it’s the injectors.
Faulty coil lead or spark plug gone or loose. Sounds like it’s on 3 cylinders but I suspect you’d hear the air leaving the cylinder if it was a loose plug.
If it’s a piston, valve etc, you’d get other symptoms like smoke, low oil pressure and likely an engine light. Hard to say really but best guesses. Hope it’s something daft and you get it sorted 🤞🏻
Rskennedy
  Clio 182
Thanks all, I will get the inlet manifold off and take a look to see if its lead/plug related.
Glad the majority think its not catastrophic... 🤞
Rskennedy
  Clio 182
So had the manifold off and it was pretty obvious what had happened. Blew a spark plug out and mashed the lead in the process.
Spark plug looked fine and no damage to the thread suggests it’s just worked itself loose over time?
Screwed the spark plug back in and the mangled lead and it started and although it’s rough I’m pretty confident new plugs and leads will solve the problem.
Thanks everyone for your suggestions and help as always!
chazza114
I did the exact same thing on the opening lap of CSF23, blew the plug clean out the head. Thankfully I hadn't ruined any of the threads, so I popped it back in and it's been solid ever since.
Rskennedy
  Clio 182
That's not the worst case scenario, thankfully.
Wonder if it was not torqued correctly.
The rollercoaster continues! Haha.
Yeah my guess is not tight enough. I’ve ordered new plugs and some magnecor leads in blue to match the rest of the hoses 💅
Am I correct in thinking it’s 25nm torque for the spark plugs? Hopefully replace all that and it will be back to full health!
