Updates.
Kicked the Extra out of the garage whilst the kangoo is getting its ecu upgrade. Ive got a new mac valve to fix high boost so made a start on fitting.
On removal the issue with the old mac valve was pretty obvious.
Clean ish break on the wire, unsure if fatigue due to vibration due to the location bolted to the turbo compressor housing. The areas surrounding the turbo are less than ideal for relocating it, so bolted it to the front panel. I dont think this is really optimal and hose length a bit longer than id like, but cant have it all.
With that boxed off, i give it an oil change as due. Valvoline Vr1 20/50 mineral oil and purflux ls218 oil filter.
Extraction pump as usual as i refuse to remove the sump plug now its leak free.
Note grill removed on the above pic. The oil filter is a nightmare to remove with the boost hose in front, fmic in front of that and alternator above. A stock gtt oil filter is relatively poor access wise but this is next level poor. 7/10 on the difficulty/arm scratching.
With that done, road testing. High boost works again, typically the boost curve is not the same and the pressure has gone down from 21psi to 19psi. Always find that swapping mac/n75 etc on tuned setups in open loop boost control always needs a tweak. Ill datalog and set up again or book it in for a quick dyno check.
Thanks for reading!!
