I spoke to the elegibilty scruitineer for the sprints and hill round this way before I did anything to my car that could be considered to be in a grey area as far as the regulations go for modified series production cars.
I sent him pictures with redline mark ups on them indicating what I was planning to do, he was quite happy with everything I had in mind, I've saved the email trails from all the discussions.
From the book:
Suspension
12.8.1.
Additions and modifications to springs, shock absorbers or suspension height are free.
12.8.2.
The original type of suspension must be maintained (e.g. twin wishbone set-up cannot replace a single wishbone suspension; a sliding pillar cannot be replaced by a MacPherson strut; a trailing link cannot be replaced by wishbones or coaxial springing).
12.8.3.
A live rear axle may not be replaced by an independent system or De Dion.
12.8.4.
A live rear axle is allowed location links. If leverarm shock absorbers are an original fitment, they may be replaced by a single location link.
12.8.5.
Suspension pick-up point positions may be altered, providing the suspension system is maintained as being the original type.
12.8.6.
Road springs are free.
12.8.7.
The wheelbase must be to the dimensions of the original vehicle, plus or minus 2% or 5cm whichever
is the greater.
So from that, cutting the top off the strut tower shouldnt be an issue but you would be better consulting the eligibility scruitineer for your chosen series before doing anything like that, just in case.
The guy I spoke to said him self that the MSA rules contradict them selves in various instances and a lot of it is down to interpretation and being seen to play the game and be sensible about what your doing.
Most people would consider modfiying a strut tower to gain some castor an acceptable modification for a race car.
What I've taken from my numerous discussions with him is that they dont mind you cutting or modifying parts of the car even when it's within the wheel centres, if you have a legitimate reason and that it's going to either make the car safer or has no detrimental impact on the strength of the chassis.
A case in point is the standard seat brackets, I asked before replacing them with 40mm T45 tube and he was all for it
Quote:
Yes, ok to remove standard column mount from bulkhead and also to remove pressed tin ! mounts from floor. Much better to do as you intend with tubes welded from sill to tunnel.
