Had a day on the car today and Russ (Sprintcup) also came over to help me which was a great help! We were working just on the shell with taking the last few bits off so that it is back to the bare shell. The rear beam was one thing to remove so this came off and then stripped down ready for the pure motorsport bearing kit to be fitted and then the beam will be sent off along with a lot of other bits for powder coating. We then made a start trimming out a lot of brackets in the shell that aren't needed but after a while I managed to break the spot weld drill bit so that was then on hold as none of the 3 local shops I checked had them in stock
This week I had a really good price for dipping the shell and also painting it back up so I think the shell will be going for dipping once I get the welding done, I have got a few options for that now so will get that sorted once I have finished my work on the shell
The bits will be going for powder coating now they are all off the car and then once the shell is ready I can start putting it all back together!
As I said the other day I have bought a low mileage FSH 182 engine which Fred is going to strip down and check over and we have been working on the specs which I think we have nearly finalised so will hopefully be ordering the engine parts before Christmas. I have been having a clear out of parts and the diff has now sold so the box will be sent off to Agency on Monday/Tuesday who will remove the Quaife and then fit a gripper diff with the CW+P.
I have marked up for the new seat rails to be fitted along with FIA slider's and the gear linkage is also going to be moved forwards so next year it will be really simple to adjust the seat position. The new brake lines have arrived which will be run through the car and also the new fuel line has arrived which will is fully braided as the one on before was just the plastic pipe and was quite exposed. The EPAS system along with the wiring kit has arrived and is now ready to go back in once the shell is finished.
Massive thanks to Russ for coming over and helping it was a great help and gave me some really good ways to do things that I hadn't thought of
I think that is about it for now and i'm afraid I don't have too many pictures to show other than the brake lines
