Here you go mate:
[TABLE="width: 822"]
[TR]
[TD]Teeth in[/TD]
[TD]Teeth out[/TD]
[TD]Gear Ratio[/TD]
[TD]Change ratio[/TD]
[TD]Overall Gearing[/TD]
[TD]MPH @ 7500[/TD]
[TD]MPH @ 8000[/TD]
[/TR]
[TR]
[TD]11[/TD]
[TD]34[/TD]
[TD]0.324[/TD]
[TD][/TD]
[TD]0.071[/TD]
[TD]36.4[/TD]
[TD]38.8[/TD]
[/TR]
[TR]
[TD]22[/TD]
[TD]41[/TD]
[TD]0.537[/TD]
[TD]1.659[/TD]
[TD]0.118[/TD]
[TD]60.3[/TD]
[TD]64.3[/TD]
[/TR]
[TR]
[TD]28[/TD]
[TD]37[/TD]
[TD]0.757[/TD]
[TD]1.410[/TD]
[TD]0.167[/TD]
[TD]85.0[/TD]
[TD]90.7[/TD]
[/TR]
[TR]
[TD]34[/TD]
[TD]35[/TD]
[TD]0.971[/TD]
[TD]1.284[/TD]
[TD]0.214[/TD]
[TD]109.2[/TD]
[TD]116.4[/TD]
[/TR]
[TR]
[TD]37[/TD]
[TD]33[/TD]
[TD]1.121[/TD]
[TD]1.154[/TD]
[TD]0.247[/TD]
[TD]126.0[/TD]
[TD]134.4[/TD]
[/TR]
[TR]
[TD]39[/TD]
[TD]31[/TD]
[TD]1.258[/TD]
[TD]1.295[/TD]
[TD]0.277[/TD]
[TD]141.4[/TD]
[TD]150.8[/TD]
[/TR]
[TR]
[TD]Crown[/TD]
[TD]Pinion[/TD]
[TD]Diff ratio[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[TR]
[TD]59[/TD]
[TD]13[/TD]
[TD]4.538[/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[TD][/TD]
[/TR]
[/TABLE]
Change ratio for the "6th" gear in that list is relative to the 4th gear not the 5th though.
So you can see that with the 39/31 the revs will drop TWICE as much (1.295 vs 1.54) as with the 37/33 when you change into fifth, I cant imagine why you would want to do that unless you think there is a significant chance you will ever be at over 134mph for more than a few seconds.
For anyone who doesnt realise, the "change ratio" is the amount the revs will drop when you change up.
So if you are at 7500 and the change ratio is 1.5 then in the next gear you will be at 5000rpm (well technically very slightly under 5K in that example as the car decelerates slightly during the change)
If the change ratios are low then its called a "close ratio" gearbox.
In an ideal world for racing an N/A car you would have a change ratio of around 1.15-1.20 normally to really keep things on the boil, sadly none of the standard jc5 clio boxes do have
