What you having done Martin?
Just getting the mapping finished off mate.
Hopefully @AlexW will be able to sort the air bag wiring and dash lights for me whilst it's there too :up:
Just read right through this, makes me look at your car in a different way, when I'm swearing about it in the morning lol.
I'll make sure its done right and looked after, plus sort all the wiring stuff :wink:
Like the owner. [emoji23]Behave lol! Look after my baby! She's special.
Photos are very cool mate. What you said about the rear arb made me realise why my car doesn't handle like the old one........now purchased!
Ring cover sounds like a brilliant addition. That was the biggest concern when I went.
Get the Pure Motorsport shims, they're marked in minutes not mm, so it's easy to work out.
They do 10, 20, 30 minute shims for toe. So just stick a 20 on the right side so you end up with 19 left and 15 right.
I've just bought a 20 minute shim as mine is pretty much like yours on the rear.
Saying that I have been trying to source the 5min metal Renault shims to bring my rear in line to the other, currently each side is slightly different, and yes it would notice (on track).
Sorry mate only just seen this. Notifications are a bit hit and miss for some reason.Right, whilst I don't have the car to play around with I thought I should start to order a few small things.
I need to sort out some shims to bring my rear toe and camber more in line. This is what I'm working with at the moment... I'll also be going to 10 minutes toe out on the front axle when I have the tracking done next.
What I'm thinking is a 3mm shim for the left rear camber. To make it -1.46 degrees. Which would bring it more inline with the right rear at -1.51 degrees.
Then ideally a 1.5mm shim for the right rear to bring the toe back out a bit. That would make it 20 minutes toe in this side and 19 minutes toe in on the left side. (which would be perfect) However I'm not sure I'll be able to find a 1.5mm shim 😞 so I may have to settle for a 1mm one (If they even do these). Which would make it 25 minutes toe in this side.
My OCD doesn't like the fact that it's never going to be perfect but it's obviously very very small differences.
Am I right in what I'm thinking @NorthloopCup or am I missing the mark somewhere here? A 3mm shim and a 1mm shim almost seems so minimal that it's not worth doing, or do I have my measurements wrong?
Any updates on the mapping Martin?
Booked any brands sessions for the summer yet mate? I just got a 172 cup to take on track this year so would be good to see you up there.
Martin, reading this is making me want to spend a fortune on mine!!!
Wish I had your budget!
Clicky :wink:
This is the old map, which we're re-doing, but needed to run it to see what this one was like etc.
Good stuff Martin!
Hopefully this will make all the hard times worth it :smile:
Although now I have no chance keeping up at Bedford haha
Just renewed the insurance for another year. £599 all in. Not the cheapest quote I had, but it's via a friend of a friend so I know I'm in good hands should the worst happen. They also have track day cover as an add on and full Nurburgring cover should I take the car back there.
Ouch. Who is this with, if you don't mind me asking? And is it on limited mileage?
PM me if you want, but I renewed with Greenlight (including optional daily track cover) and all mods declared to 260bhp at the fly. Two years no claims, 32 years old. 7500 miles, £329.
Glad to see it will all be sorted for Bedford :smile:
