182 Titanium Yorkshire B Road Project
Check the reluctor rings on the driveshafts and the rear discs. That's where the speedo signal comes from and I've had crudded up rings (ooh err) and sensors covered in swarf cause all kinds of weirdness
What a pain, I know the feeling of getting your car back and it still not being right. It happened pretty much every time I did anything to my old Megane
Let me know if you need any bits, I'm only in Leeds and always have parts on hand
Have you checked the ABS sensors? Poor connection or broken wires can affect the speedo.
Yeah all the rings and sensors are now new and connections been cleaned. reading normal on live data when I have it plugged in on the OBD reader. The needle on the speedo looks like it gets stuck and judders so I’m hoping it’s the motor on the clock itself.
Appreciate it. Don’t suppose you have rstuner or clip for the airbag light? Happy to pay obvs.
Thank you both for your support in my pain here! Now I’ve driven it today I remember why I’ve bothered!
Yeah I've got both. If you're ever close let me know and I'd be happy to turn the airbag lights off and do a scan of your car too mate
Legend, I will send you a private message when I know I am going to be free. Really appreciate it.
When I took the car in to get the tyres swapped over I didn’t think to tell them not to overtighten the nuts. Anyway they may as well have welded them on it was so tight.
Frogjam to the rescue again and some fresh studs and nuts for peace of mind.
I’ve been chasing this wobble and turns out it wasn’t the wheels, £400 down the swanny!
and think I’ve found the culprit which is this 50p shaped spacer that looked like someone’s been playing frisbee with. Ordered a couple of new ones from pure and will fit next weekend to see if that solves it once and for all.
Anyway drove 300 miles to Newcastle and back yesterday and sans wobble over 70 it was great. The speedo even came back to life on the drive there. Then decided to stick at 70mph the whole way back.
New/used dash clocks arrived today so got straight on fitting them to see if my speedo issue was resolved.
BAM!! Sorted! I have unfortunately now added 15k miles to the car. Who thought the mileage built into the cluster was a good idea?
Also fitted new suede gaiter with blue stitching because. Oh and cracked the dash leaning on it so will have to glue that back together. I hate the flocked dash anyway. Might buy a spare one and cover it in Alcantara instead to match the roof and A pillars.
Took it for a drive to check everything over and I’m not sure if it’s the placebo effect knowing everything is working for once but the car seemed much faster.😅
Just stick your old clocks back in for now and see if you can find some closer to the mileage mate
Saves ruining your cars history
I’m planning to send the originals off to get reconditioned. Found someone on fleabay. Interesting that it’s that easy to manipulate the mileage though.
Fresh spacers arrived so got them fired on.
Also spotted that the scabby sill has now got dramatically worse since the MOT, so that is going to need to be cut out and welded. Should be fine until winter though right?
Castle Combe was a blast. Drove 350 miles there via London for work and no issues.
First outlap and the whole thing cut out and lost power for a millisecond. @Myfanwyi took all of 7 minutes and 34 seconds to fix it. I left the go pro on by accident so timed it…
Engine cover had been pressing on the plug that goes onto the coil pack, a sensor had unplugged itself by the oil filter and id sandwiched the maf sensor at a weird angle when I did the coil pack. Anyway one of them of all of them were causing it. No issues the rest of the day
Car felt great on track, was pretty tentative myself knowing I had to get it back 250 miles but watching the footage from the GoPros I went from 1:37’s down to 1:33’s by the end of the day
@Speedo Gonzales also coded my airbag light out being the top man he is. But they came back on during the drive home. Will see if they turn back off when I’m next in the car.
Was debating sacking the whole thing off and selling but car has been so good this trip so next up is welding up the cill and undercoating for winter. Will need to get that plug seen to as well.
Done absolutely nothing with the car and barely driven it since Combe.
Finally got the sill welded and they did the rear arch as well. It’s rough as a badgers arse but it’s done the job.
Something a bit less rough. My overnight (2 months) parts from japan (china) arrived today, so got excited and sacked off the rest of the work day to get them fitted. Need a little bit of moving about so I can actually reach the pedals and steering wheel, currently set to bradford RS3 elbow delete spec. This afternoons job.
Very happy with the quality considering they were a quarter the price of real recaros. custom logo on the headrest and custom blue stitching.
View attachment 1764794View attachment 1764793
How much and what did you do for subframes? Always been a bit scared of trusting a random chinese factory with safety items, but they look really good.
They were about £500 a seat plus shipping and taxes, genuine carbon fibre. I didn't use their mounts and just used what I had for my corbreaus. What they supplied was pretty flimsy. I had measured up and confirmed with the seller the dimensions before going forward with it
Clio has barely moved since fitting the seats. Me and my dad went halves on a used range rover sport (he lives next door and is 70 so doesn't use it a whole lot).
Went to take it out this weekend and it decided to do the immobiliser fast flashing lock out the last few times that ive got in the car and wasted 30 minutes of my life before it decided to start each time. One I was picking up a takeaway and the f***cking thing was cold by the time I got home....
Got a guy coming to code a couple of new keys tomorrow, I only have 1 key so definitely worth having a spare regardless. If that doesn't solve it then I will send the UCH off to get reconditioned as well. Also noticed that my aftermarket stereo has stopped beeping when i turn the key off, I cant hear the thing over the exhaust anyway so will probably just pull that out with the UCH and get a blanking panel.
Had a mobile locksmith out to cut and code a couple of new keys for the Clio. All seems to be good. Let’s see if it solves my flashing immobiliser issue.
If it is the decoder ring, can you just plug and play another one from a scrapper?
Decoder ring is plug and play, it rarely fails however. If it continues, need it scanning with clip to see if anything stands out then go from there.
Car has been fine since the new keys were coded. Then on Wednesday I popped to the post office 5 minutes up the road in it and had the flashing immobiliser back!!! Then unplugged the battery and ended up with just a solid light, so RAC towed me home.
Since then I:
  • tried the original key, nothing solid red light
  • wiggled all the relays and fuses in the engine bay, tried new keys nothing solid red light
  • replaced the decoder ring, tried new keys nothing solid red light
  • tried the original key again and it fired it up first time, then tried the other new keys and again both worked fine again
I have absolutely no idea what the cause was or how to stop it coming back, UCH? Wiring?
Would be nice to be able to go for a drive and not have to be scared to turn it off for the fear it wouldn't start back up again!
Hard to say without looking. Basically, solid red immob light means key is recognized but communication between ecu and uch is not working.
last time i fixed similar issues, it was knackered wiring on the engine loom. I would start by checking the white engine bay plug for corrosion. Then check the twisted pair of can wires (white and purple) across the plug for continuity. If thats ok start checking the can wiring, power and earth from white plug to the ecu for continuity as the loom can break.
Also could be uch failing. Id send it away to dieselrepairspecialist on ebay for a once over.
Thanks pal, appreciate your help, I'll pull the UCH and send it off to him, found him on ebay.
Yeah that's deffo your issue
Check the grommet on the firewall. I bet they've installed the alarm like on mine where they've left the grommet out like c***s
Had a little look through today and the grommet is there and nothing is damp all the wiring looked intact on all the connectors and nothing looked corroded. Just s**t loads of carpet glue on the firewall.
UCH should arrive with diesel pump repairs today/tomorrow so hopefully there’s something obvious there.
Tested all the fuses and they seem to be fine as well.
I did find a couple of random black wires in that area (speakers or something?) that weren’t taped up so I do wonder if that’s causing a short, now taped up
UCH back from repair. 24 hour turn around, thanks for the recommendation @Brigsy
He said there were no obvious faults but redid the 16 pin plug just to be safe.
Back in the car and it seems to have resolved all my other gremlins, so whether it was this or something shorting who knows but it appears fixed.
- no more random esc light
- no more airbag light on and off
- seems to have fixed the immobiliser issue but too early to tell
If I could have 12 months of no major issues that would be lovely! Planning plenty of track time in 2026.
Been a while since I’ve touched the car with the weather. MOT is coming up so have it a clean and a little spurt today.
- Started first time no problems
- Small oil leak from somewhere but oil level seemed fine just a bit of a rainbow on the drive where it had been sat
- rust bubble starting to form on the bonnet
- really need to get the rear arch painted and blended after the welding
- planning to get it serviced and all fluids changed (oil, gearbox, coolant, brake fluid) along with the MOT so it’s in fine fettle for the nicer weather seen as it spent half the summer in the garage getting sorted last year!!
Set about sorting the melted exhaust trims but the trimlok I bought isn’t wide enough. c**k. At least I know how to make it neater for the next time!
Overall scrubbed up well and looking forward to enjoying it this year, Croft and oulton park already booked in and will be at cliosport festival as well.
I am pretty sure I will be getting rid at the end of summer for something a bit more plush. Wife refuses to get in it and I fancy some European road trips in something engaging that isn’t the Volvo or range rover
Was dry yesterday so armed with some slightly larger (maybe too large) trimlok I set about attempting the exhaust surrounds again. Turned out quite neat but possibly its a bit too thick lets see.
Delighted with my work I thought this required a test drive, car started up and the idle was all over the place... normally its really smooth and has no issues. Plugged the OBD reader in and only codes showing were standard stuff for missing parts off the car. Checked live data and again all seemed normal with throttle positions etc...
Pulled forward on the drive and found a rainbow oil slick left where its been sat (been in the same place about a month so not too worried) Oil level seemed fine took a look underneath and looked to be mainly on the gearbox, so could be the gearbox again from the driveshaft seal that was sorted previously.
Its booked in for a once over and MOT next week anyway so will see what they find but hopefully its an easy fix and I can enjoy it when the weather gets better.
Told you I’d be back but sooner than I thought. Took the thing out for a quick drive today.
Electrical warning light and limp mode has come on.
The when I got home turned it off and the electrical warning light went off cranked the engine again and was revving its nuts off on its own to 3-4K revs like it was the other week.
Any ideas?
So with the help of Chat GPT and my code reader I have to the conclusion that my alternator is failing.
Chat GPT informed me that the ECU might have had a blip in voltage to the throttle pedal and thats why the electrical light came on and it went into limp. The fact it was hot added to its suspicions and the reason it revved when i turned it back on was because it was relearning the throttle position.
Armed with this knowledge i went back out with the code reader started the car up again, this time electrical light was on again but started fine with no fluctuation in revs. I checked the voltage and it was pretty low at around 12.78V. This time the code reader picked up DF129 pedal incoherence between track 1 and 2.
At this point I thought, throttle pedal, but with the low voltage, that might be why its throwing it, so i decided to turn everything on, lights, radio, heated screen, etc.. and watch the voltage, which dropped down to 12.08V
When i turned everything off again it rose back to 12.5V.
My question to the much smarter people in the room than me is.... is it the alternator? Is heat soak causing it to fail more when driven hard?
f**k chatgpt off for starters :LOL:
Voltage should be 13.8+ when running. Id verify with test meter.
Needs scanning with clip to see whats stored. Might be pedal, tb or wiring at a guess.
