Have you checked the ABS sensors? Poor connection or broken wires can affect the speedo.Slowly working my way through the list.
New earth done speedo still not working so ordered a set of clocks out a breaker to see if they work.
Yeah all the rings and sensors are now new and connections been cleaned. reading normal on live data when I have it plugged in on the OBD reader. The needle on the speedo looks like it gets stuck and judders so I’m hoping it’s the motor on the clock itself.Have you checked the ABS sensors? Poor connection or broken wires can affect the speedo.
Check the reluctor rings on the driveshafts and the rear discs. That's where the speedo signal comes from and I've had crudded up rings (ooh err) and sensors covered in swarf cause all kinds of weirdness
What a pain, I know the feeling of getting your car back and it still not being right. It happened pretty much every time I did anything to my old Megane
Let me know if you need any bits, I'm only in Leeds and always have parts on hand
Yeah I've got both. If you're ever close let me know and I'd be happy to turn the airbag lights off and do a scan of your car too mateAppreciate it. Don’t suppose you have rstuner or clip for the airbag light? Happy to pay obvs.
Thank you both for your support in my pain here! Now I’ve driven it today I remember why I’ve bothered!
Legend, I will send you a private message when I know I am going to be free. Really appreciate it.Yeah I've got both. If you're ever close let me know and I'd be happy to turn the airbag lights off and do a scan of your car too mate
I’m planning to send the originals off to get reconditioned. Found someone on fleabay. Interesting that it’s that easy to manipulate the mileage though.Just stick your old clocks back in for now and see if you can find some closer to the mileage mate
Saves ruining your cars history
What you on aboutYou're not kidding when you said it was rough, f**k me Rich 😂
How much and what did you do for subframes? Always been a bit scared of trusting a random chinese factory with safety items, but they look really good.Something a bit less rough. My overnight (2 months) parts from japan (china) arrived today, so got excited and sacked off the rest of the work day to get them fitted. Need a little bit of moving about so I can actually reach the pedals and steering wheel, currently set to bradford RS3 elbow delete spec. This afternoons job.
Very happy with the quality considering they were a quarter the price of real recaros. custom logo on the headrest and custom blue stitching.
View attachment 1764794View attachment 1764793
Car has been fine since the new keys were coded. Then on Wednesday I popped to the post office 5 minutes up the road in it and had the flashing immobiliser back!!! Then unplugged the battery and ended up with just a solid light, so RAC towed me home.Decoder ring is plug and play, it rarely fails however. If it continues, need it scanning with clip to see if anything stands out then go from there.
Hard to say without looking. Basically, solid red immob light means key is recognized but communication between ecu and uch is not working.
last time i fixed similar issues, it was knackered wiring on the engine loom. I would start by checking the white engine bay plug for corrosion. Then check the twisted pair of can wires (white and purple) across the plug for continuity. If thats ok start checking the can wiring, power and earth from white plug to the ecu for continuity as the loom can break.
Also could be uch failing. Id send it away to dieselrepairspecialist on ebay for a once over.
