182 Titanium Yorkshire B Road Project
Krarl
Check the reluctor rings on the driveshafts and the rear discs. That's where the speedo signal comes from and I've had crudded up rings (ooh err) and sensors covered in swarf cause all kinds of weirdness
What a pain, I know the feeling of getting your car back and it still not being right. It happened pretty much every time I did anything to my old Megane
Let me know if you need any bits, I'm only in Leeds and always have parts on hand
Rskennedy
  Clio 182
Have you checked the ABS sensors? Poor connection or broken wires can affect the speedo.
Yeah all the rings and sensors are now new and connections been cleaned. reading normal on live data when I have it plugged in on the OBD reader. The needle on the speedo looks like it gets stuck and judders so I’m hoping it’s the motor on the clock itself.
Appreciate it. Don’t suppose you have rstuner or clip for the airbag light? Happy to pay obvs.
Thank you both for your support in my pain here! Now I’ve driven it today I remember why I’ve bothered!
Krarl
Yeah I've got both. If you're ever close let me know and I'd be happy to turn the airbag lights off and do a scan of your car too mate
Rskennedy
  Clio 182
When I took the car in to get the tyres swapped over I didn’t think to tell them not to overtighten the nuts. Anyway they may as well have welded them on it was so tight.
Frogjam to the rescue again and some fresh studs and nuts for peace of mind.
I’ve been chasing this wobble and turns out it wasn’t the wheels, £400 down the swanny!
and think I’ve found the culprit which is this 50p shaped spacer that looked like someone’s been playing frisbee with. Ordered a couple of new ones from pure and will fit next weekend to see if that solves it once and for all.
Anyway drove 300 miles to Newcastle and back yesterday and sans wobble over 70 it was great. The speedo even came back to life on the drive there. Then decided to stick at 70mph the whole way back.
Rskennedy
  Clio 182
New/used dash clocks arrived today so got straight on fitting them to see if my speedo issue was resolved.
BAM!! Sorted! I have unfortunately now added 15k miles to the car. Who thought the mileage built into the cluster was a good idea?
Also fitted new suede gaiter with blue stitching because. Oh and cracked the dash leaning on it so will have to glue that back together. I hate the flocked dash anyway. Might buy a spare one and cover it in Alcantara instead to match the roof and A pillars.
Took it for a drive to check everything over and I’m not sure if it’s the placebo effect knowing everything is working for once but the car seemed much faster.😅
Rskennedy
  Clio 182
Just stick your old clocks back in for now and see if you can find some closer to the mileage mate
Saves ruining your cars history
I’m planning to send the originals off to get reconditioned. Found someone on fleabay. Interesting that it’s that easy to manipulate the mileage though.
