Re: James/BigAsh 182 Race Car by TDF... It doesn't get much better than this! *Pic He
Thanks Mark appreciate it You must be classed as a fixture of FF-Racing now with the amount of help you give me!!
James - PAS current draw is only an estimate; please don't take it as gospel
Reg the above ^.. well you know my thoughts...
Was it all just 'shoved' into the cavity under the dash?
Sorry mate I missed this off beforeWas it all just 'shoved' into the cavity under the dash?
Yes it's only a matter of everything off check it all over, clean up as there is PAS fluid and engine oil over everything and then paint up some bits so they are easier to keep clean and then back together on its wheels!Holy s**t - back together by November?
I thought now the season was over you'd be taking a few months out and resting. I wish I had your energy levels mate LOL
Yes it was just lifted up against the roll cage and cable tied up!It was hidden well if it was. I'd have nightmares about cabling like thatOCD would go onto overdrive.
Need to decide how extreme to go as want to move the seat rails, gear linkage and modify the front turrets but I can't weld and think all that will be very costly to get done elsewhere
Lol!!
On a side note, I've watched your 'ring lap now. With some kerb action (in the right places) and some adjusted lines, you'll go very fast round there mate.
Don't tempt me with the shellI have already considered it!
Ill have your shell James, can collect whenever!
Very true and I dont think I will ever repeat most of my mistakes from the last year but personally I don't think the clio is a mistake as a race-car! We'll see what happens
No issues as such but want to build up the front turrets to get more caster and also relocate the gear linkageDid I miss the welding issues somewhere? What needs fixing?
Torque wins races mate
TDF wanted to do something similar to mine and spent time trying but it's just not possible unless you change the selector on the boxThere's a gear linkage system developed for the 106 - by Colin Satchell - satchshift, it's fecking AWESOME
Runs rod's through the car - puts the gear nob high up and near your left hand. I wish someone like BTM/K-Tec would develop a similar system for the Clio. Or a cable system because frankly the gear stick in a Clio is in completely the wrong place unless you're a 5' 2" girl
Yes I agree but starting from fresh I would do things differently and if I can get a good price for my shell so that it wouldn't cost me much to start again then I think I would do itCertainly not worth starting again to make those changes!
Rollcentre did it mateFair enough mate. Custom did your cage iirc?
Had Fred given you potential engine spec options yet? Like you said, peak performance isn't key. Torque wins races mate
Haha probably! I think I said it to you when we were away but the skoda fabia VRS diesel tuned up could dominate our series if someone could be arsedI wonder if a 260bhp 1.9 TDi clio is more cheaply achieved than a 260bhp 2.0 petrol one?
would certainly have a good torque spread too of course.
Depends on the circuit surely? Slow corners needs better torque and traction no?
