172 Cup 0-100 video
MarkCup
Finally got round to doing this, only the, ahem, pit lane was damp, so traction through to 3rd was tricky.
I reckon I hit 60 (63ish on the clock) in 7.1 on both runs, but got to 100 in 17.5 then 17.0.
Run1
Run2
You had the rev limiter raised on that??? How do you get to nearly 70mph in second??? My cup will be lucky to hit 60 in second gear
My phase 1 172 almost touches 70 in second gear but I think i remember someone stating the ph1 172 had slightly different gear ratios?
BTW what is the beeping you hear around 80-90mph on the vid?
Rob
Mark has the R-Sport fitted.
Knowing Marks car, the beeping will be the Origin speed thing.
^ Yep - B2 overspeed warning alarms at 80mph, but always runs 2-3 seconds behind actual speed.
If it's dry tomorrow I'll have another go...with the mount a bit higher to give a full view.
cliobuyer said:
Yeah the mk2 has shorter gearing.
Bit of a boring vid. No boobs?
Lol Boobs would be good. They tend to help the 0-100mph time
However the beeping would be the pacemaker if boobs were involved :D
