If I may offer my two penneth.
There is a lot of money being thrown around in here, talking about RS2 manifolds and throttle bodies. So lets take an average TB conversion, £2500 including ECU? You're looking at a 20-25bhp gain over a healthy 182. Good linear torque curve, and healthy amounts of power, right up to the red line at 7800rpm.
Now I know it's been said many many times about how expensive N/A tuning is, but lets just put this in perspective. For the same amount of money, I can take the S4 and have hybrid turbos or second hand KO4s from the RS4 fitted, RS4 intercoolers or a large centre mount, injectors and a map. Those few bits will quite happily see 380bhp. Which is a gain of 110bhp?
In my eyes, tuning the clio engine is such a waste of money. Which is why my 182 has never even been remapped.
The S4 will cost you a fortune to use on track, they rip through expensive tyres at a hell of a rate and they drink fuel like they have a hole in the tank if used hard at 380bhp as well.
I agree that an RS2 is expensive, and Throttle bodies even more so, but I think you need to look not just at purchase costs but at resale costs too.
REALISTIC figures for an RS2:
Buy it, fit it in a couple of hours and have it mapped by Mike from MWM is about 1500 quid or so all in. Plus a couple of hundred for uprated mounts.
Resale price is going to be about 900-1000 or so, and over 100 for the mounts, and Mike will put your old map back on after you refit your standard inlet for basically not much more than a drink.
So to have an RS2 on your car giving you an extra 20 odd bhp and a healthily extended useable rev range (7500 most I would advise unless you fit rod bolts) is going to cost you around 700 quid all in, plus a couple of afternoons of your time to fit and remove it.
Thats a seriously good value upgrade if you are going to own your car for 18 months IMHO. And if you buy secondhand, you can do it for FAR less than that, probably sub 400 quid realistically.
Throttle bodies are a bit worse on cost of ownership unless you buy secondhand in the first place as they depreciate more, they cost more generally in mapping and they require chopping about of the loom and/or swapping the throttle for a manual one in most cases.
But even still with bodies, you spend out your 3K ish for cams and ascociated bits and mapping or roughly 2.5K if using secondhand bodies, and still see 2000 of it back.
Cams you are looking at about 1300 quid fitted and mapped for new, or about 1100 fitted and mapped for secondhand, but the resale value is only around 400 quid, and you are probably going to have to spend that to get them swapped back to standard realistically, so essentially once you have spent the money on them its gone forever, not quite as bad if you are having your belts done anyway of course.
Exception is if you can do them yourself of course, so for me or Danpl6 or Mike etc a set of cams is 400 secondhand or 600 new, and get 400 back selling them, so only cost is 100 odd quid for a belt kit twice to fit and remove them and some of our time.
Thats the biggest thing that the numpties earlier on this thread banging on about the cost of an RS2 versus Cams seem to forget, you spend a couple of hundred more on the RS2 initially, but you then get most of your money back when you sell it on, also unlike cams if you have an engine die, the RS2 wont get killed by swarf but the cams potentially will.
So yes I agree with you that its a lot of money to spend out, but I would argue if you spend it the right way, you will get a hell of a lot of it back, so can enjoy a moderate performance increase for very little overall cost, with your S4, it will be cheaper to tune, but you'll see your costs per trackday being MUCH higher than one of us having just as much fun in our tweaked clio
