EPAS on 172 Cup
  182/RS2/ Turbo/Mk1
Just to update.
New dci rack no longer available. The one that turns up if you order one is a 1.2 petrol one which has more turns lock to lock.
_WILL_
  172 Cup
So I was at Bedford Friday night and experienced and issue. I was getting a knock through the steering, it was inconsistent and only happened on changes of direction, when the front was loaded up. It has also done it a few times when parking!
its the first time I have run track tyres and camber bolts on the car so I imagine the loads have increased.
It it feels like a spline might be slipping. I can only think that would be the UJ to rack pinion, I have checked it and it is still torqued up.
Has as anyone got a picture of theirs fitted ( UJ to rack, should be able to see it down the back if the engine). I want to make sure I haven't done anything stupid! Also if anyone has had similar and has any ideas please let me know.
  Clio 172
I had that issue on both of my DCi racks, running AD08R's and -1.5 camber. Changed to a looped PAS rack and it's much better. Still get the odd knock when parking on high grip surfaces though, can't really pin down what's causing it, seems like the noise comes from within the rack.
  FF Clio 182
I have a knock in the rack at the moment, sounds like a loud click. Can hear it at certain points when turning the wheel.
_WILL_
  172 Cup
this is what I get, left lock I get a quiet on and then a loud one approx half a turn later, and one small right hand down. It's very loud with head under the bonnet. I will dig into it a bit and see what I can find.
yeah that is what I am getting. I will see if I can get it on a ramp somewhere and have a look.
  Clio 172
My current thinking is that with the motor being on the column all of the turning force goes through the pinion gear. When the load is too high it sometimes locks up and then suddenly releases, causing the knock.
With the hydraulic setup there's actually not much turning force going through the pinion gear as when the wheel is turned and the valves open it's the hydraulic fluid pushing the rack along that does most of the work, the pinion is more of a fail safe in this setup.
I'm guessing the force required to turn the wheels on a lesser powered clio is smaller due to less castor, camber, more narrow tires, generally a less sticky compound, etc meaning the rack doesn't suffer from locking up.
_WILL_
  172 Cup
The noise on mine is defiantly coming from somewhere in or under the engine bay. After a very quick look it seems like it is coming from the rack. Not sure if it is rack mount or internal to the rack, or inner track rods.
I'm hoping to get under the car this week so if I find anything I will let you know. May try and get some videos etc as it may help people diagnose the same issue in the future.
  FF Clio 182
Like I said; mine clicks but not looking into it as my inner tie rods need changing so once they done and if the problem is still there will look into it.
As said above though, about the pinch bolts is taking more force as it's turning the column not the actual rack seems a good possible cause. Looking at the universal joint, it doesn't look that robust
  Clio 172
My noise stopped for a good few months after fitting the looped rack so I don't imagine it's the UJ or column otherwise the noise would have never gone away.
_WILL_
  172 Cup
I am just going to give it all a once over and go from there. If I find anything I will report back.
I have a spare used rack sat in the shed to I can always drop that in if needed. Is it a case of fill with pas fluid and link the in and output from the PAS system to each other?
  Clio 172
I blanked the ports up near the pinion and linked the 2 ports that are on the rack body. Drained 90% of the fluid before looping.
_WILL_
  172 Cup
I have resolved the noise issue on my car. Steering race to subframe bolts, the torque had relaxed slightly. Re-torqued and noise has gone. There was no noticeable movement but bolts were not tight enough.
Going to replace the and put some new nyloc nuts on as well. They are a bit of a pig to get to tho so not sure how to get a torque wrench on them!
  FF Clio 182
What is the correct torque setting for these bolts ?
_WILL_
  172 Cup
Not 100% sure, but for he standard rack they are 50nm I think. So I used that as a starting point. They were a fair bit lower than 50Nm. But the passenger side one is a b**ch to get a torque wrench to so I just did it FT.
  FF Clio 182
Yeah I checked and they are 50nm. Like is said mine were done up with an impact gun so I can't see them being loose
  Clio 172
I'll give this a go next time I'm under the car. I thought I'd done them FT but as you say they aren't easy to get to so I could have easily tightened them less than I thought I had.
  Clio 172
Just a thought, has anyone tried a 197/200 rack for size? Although a quick Google shows a lot of issues with these knocking too, similar issue to what we are experiencing maybe?
_WILL_
  172 Cup
I am not sure about the 197 / 200 rack but I know earlier on in the thread there was a lot of torque about the twingo RS track, which looks like a nicer cast aluminium part. However I think there were some alignment issues, and I am not sure if they were resolved. It will prob be in the first few pages of the thread. I think people discussed machining the mounts to fit, but personally I am against machining the mounts.
Its a shame as I think it would be a good rack to use.
However its def worth checking the rack mount torques before you change anything, I was convinced mine were tight and there was no movement I could see or feel, but the torque was low and tightening it up fixed the noise.
I know the 1.2 petrol rack is more turns lock to lock. Just wondering if you checked to see if the ratio was the same?
In other words if you do 1 complete turn of the wheel does it move the rack the same distance on both the 1.2 and dci rack? If it does then there should be no issue fitting the 1.2 rack. The speed of the steering will be the same, you will just get a tighter steering lock with the petrol one.
Just to update.
Grandpa Joe
This is a very good point, and something I'd like to know as I'm trying to source a new/reconditioned rack and can't find a 2.75 DCI one anywhere.
On the old Fiestas the XR2 has a 3.0 turn rack and the base spec was 3.5 turn. Same ratio but the XR had lock stops.
I don't think this is the same on the Clios though. The early non PAS Clio racks have a 55mm pinion, EPAS are 50mm and the sport PAS racks are 43mm. If you go off that then it works out as 43mm = 2.75 turns, 50mm is 3.25 turns and 55mm is 3.5 turns. Unless the 2.75 DCI racks have a 50mm pinion rack and lock stops for different offset wheels and wider tyres.
Has anyone driven with both the 3.25 and the 2.75 and noticed a massive difference?
Grandpa Joe
I've found a place that can refurb racks for £60-70 with a 24hr turnaround so its possible to buy a 2.75 turn one used and get it fixed up. Now I need to decide what to do.
If they are different ratios the 3.25 will be easier to turn with no PAS but slower, still, as far as a non PAS racks go 3.25 is short-ish. You can buy Quaife quick-racks for Honda Civics which are 3.25!
If they are the same ratio but the 2.75 has lock stops then 3.25 might present issues by giving a tighter turning circle which would mean the possibility of catching the inner arches with the tyres.
Grandpa Joe
Didn't know about the perma-ban...
Got him through Facebook. Turns out the 3.25 is a slower rack than the 2.75, no lock stops involved so I will assume the 2.75 has the same 43mm pinion as the RS and the 3.25 has the 50mm pinion.
Thats's the info I was looking for.
So dci rack is what you need then if you want quicker steering then. Shame as there seem to be lots more petrol ones about and you can still buy it from Renault as well, but not the dci.
Grandpa Joe
You can get the dci rack refurbished.
3.25 is by no means slow though. It's the same as a E36 M3 ( it's 3.25 with lock stops to get 3.0). 306 gti is the same, civic EG and so on.
It's just slower than what we started with which is a fairly quick rack, quicker than an EP3 2.83 or DC2 2.9.
I never struggled with the steering on my Fiesta and that was a 3.5 with lock stops to get to 3.0. So I'm half tempted to get the 3.25 rack and not bother with any EPAS at all.
True, you probably wouldn't even notice if you didn't know.
I already have a dci rack on the race car anyway so might just get that refurbished when needed.
  Clio 172
An interesting observation. I switched from my AD08R's to my winters a couple of weeks ago. The winters obviously have considerably less grip on a dry surface than the AD08R's and since fitting them I havent had a single knock.
If you've already got epas then why not just vary the assistance until you're happy?
My rack has play in it so need a new rack and was just going to switch back to the manual column, save some weight instead of the motor being there, with the car not being used much as of next year I want the most feel and best response I can get
