incy-spiders Clio 182 turbo
I'd it actually being done or just dropping it off? What time as I might fly over and check it out.
On it!
Just got home!! Bit of an up and down day... Arrived at EFI at 11 this morn, got straight to work with off boost mapping all went really well, got to mapping with boost and we were getting some nice numbers climbing closer and closer towards 200bhp, Chris said more boost was needed so set about winding the actuator in, gave it a few more runs and it became clear there was a issue! :( we were getting great boost up to 4250rpm then started to drop quite badly,
We then thought adding a boost control solenoid would keep the boost more steady but after a lot of head scratching turns out my Gen90 didn't have the latest firmware to control the solenoid!!!
Ah well back to the shoddy actuator then, we decided to run a tad more boost but map it back to a safe level at the peak of boost keep it like that for now, it made 229.4bhp and an impressive 227.7 ftlb of torque. Chris said with a decent actuator it would of easily made more so I'm going to get a forge one to smooth out the boost soon.
TBH I'm more than happy with it as it is, I flys that mid range torque is amazing, both me and my mate were laughing all the way home!! :)
Mega thanks to Chris for not giving up on it and an awesome job!
Yeah thinking the same, was more concerned about the boost spike to be honest, would of liked a more linear curve but I'm more than happy with that power!
Great result! I think boost is on the cards for my cup next year, finish the barn conversion this year and save my pennies!!
Could you put a list of things together required to do a turbo conversion? Considering keeping my 182 and putting forced induction on it.
Engine dynamics supplied my kit mate go to there website. Other guys on here do turbo kits too. Parts that don't come in the conversion I did are things such as my ECU, fuel rail, clutch, wideband, r26 map sensor, oil cooler, also worth considering refreshing things like timing belt kit, aux belt kit, if you are removing head to fit low comp gasket like I did, cam seals etc.
Roughly here's what I spent for the basic parts that will get you boosted.
Engine dynamics 230 kit without management £2200
GEN90 ecu £800 2nd hand
Megane R26 map sensor £80
PH 1 fuel rail and regulator £40 (not essential but a really good idea)
Helix paddle clutch £190 (not essential but you don't want the chance of clutch slipping on mapping)
Mapping £300 +
Hope that helps
Hey guys, a mate of mine had a play with his camera gear while we were watching my car on the dyno and came up with this awesomeness!!! Cheers Timmy
Enjoy, love the 3d graph!!
Thanks Incy! Glad it did the beast justice.
Thats pretty cool! How did he do the graph out of interest?
Re-drew the graph in vector and then projected some 3D lines along them using Cinema 4D. :)
