That made me lolHate looking at rust and dirt.
he's proper filthy as well!! Probably why he hates seeing it!That made me lol
Id watch out Alex I've heard he likes to pay in sexual favorsI heard the word Filithy....
Your mum. Or so the rumour goes. Lol!Who's Filithy?
Alex is a hero, proper gent and always willing to help others out.
Flol at buying a new box but at least is got a lsd. [emoji41]
Graham has gross clothes.
Will have to sort that PMS. I'm sure it's a case of just tinkering around with with it for hours until it's right. Nothing a 13mm and an allen key can't solve.
The shifter does take some getting used to, and as Graham said very minor adjustments can improve it.
Any excuse for a diff :wink:
I think I put a brief how to somewhere on here for adjusting the pms linkage.
Two hours crawling around in the pouring rain I got it perfect.
I set it in 2nd then tweaked it bit by bit to get the higher gears. 5th is a very short shift.
I've got a genuine seal going spare for the box too if you want it posting out.
How old is the diff in your car?
There was an issue with the older units where the oil seal collar would come unstuck and cause an oil leak.
The oil seal collar is that silver sleeve that sits over the splines. On the older diffs this is just glued on to the shaft, and over time the glue breaks down and the oil tracks along the splines making you think the gearbox oil seal is at fault.
If you look at this pic you have taken the splines appear to be full of oil, if it was just leaking from the gearbox oil seal itself these splines should be dry, so I reckon there is a possibility that might be your problem.
Very interesting thanks mate. I'll have to keep a close eye on that then. What's the fix??
Although I think I might have just poured oil over the splines before taking that photo. Can't remember for sure now.
What I can't work out. Surely this collar can't be fixed to the splines? If it was then when it was spinning it would surely destroy the seal around it so quickly?
The oil collar is fixed to the splines yes, that's how it works, it seals against the gearbox oil seal. On the older models the collar is glued to the splines.
On the new units the oil seal collar is an integral part of the shaft, no glue anywhere in sight! If that is the problem the good news is gripper will fix it for free by fitting a new shaft. The bad news is you will need to remove the diff from the gearbox and take it to them.
That would be a right pain in the arse if so
Remove the actual diff from the gearbox? Or just take the gearbox to them?
Arghh not what I want right now.
Hopefully this is not it in your case, and it was just a dodgy gearbox oil seal, as yes you would actually have to remove the diff from the gearbox and take it to them.
Dayyymm this is a clean track toy, very nice going mate Just curious was it black spray paint used on the inside of the car?
Thanks mate.
It was just done with a brush, easier to do, cheaper and easier to maintain :smile:
I'm praying that mate because I'm living on credit these last couple of months trying to catch up. But knowing my luck it will be this collar
The fact I still had a couple of drips leak, even after I had changed the seal is what worries me.
I'm desperate to get home now to see if anymore has leaked out since taking the car for a test drive around the block.
I wouldn't be able to remove the diff from the box myself unfortunately, I'd have to pay Gripper to do this or a local gearbox place.
Thanks for posting and giving me the heads up though.
Fingers crossed for you buddy! Hopefully this is not the case.
One way to check is to get a firm grip of the collar and try to move it. If it move's independently of the shaft it is definitely the older glued version and the glue is definitely gone. It will only move if the glue is quite badly gone though.
The cheap/easy fix would be just to glue it back on which can be done in situ, but this is not ideal.
If you knew how old the diff was it would give you more of an idea. They switched to the integral collar about 3 years ago.
Should it not move at all? Because from memory there was a tiny bit of movement when I carefully took the old seal off. But it wasn't free moving and completely loose.
If the car hadn't been off the road for so long already, it wouldn't bother me too much, but buy the time this gets sorted, if it is the problem, it will pretty much be track season over for the year.
I'm still surprised it was even glued in the first place. How can glue hold moving parts together lol!!
I've sent @BIGASH a text, to see if he knows how old the diff is. I expect that even though it had a recent rebuild, it's probably older than the 3 years you mention.
No it shouldn't move at all. I had one that gone really bad and the collar actually came off completely!
It was a poor design in the first place, over time the gearbox oil dissolves the glue and the collar comes loose.
Gripper rectified the problem a few years ago and will fit you the new design of shaft free of charge under their lifetime warranty. But you will need to get the diff to them.
What a load of hassle!
You probably have to be the original purchaser too right?
Although James (being that original purchaser) very kindly said that he would help me out with it if it ever needed to go back to them.
Guess I'll have to wait and see if there is any oil on the floor when I get home now. I expect there will be![]()
As far as I am aware you don't have to be the original purchaser no, the warranty is on the diff not the person who bought it.
Would be handy if so. But I wouldn't want to say that when speaking to them, just in case it blew my chances of a fix lol. Until I knew for sure. Wonder if I can find out from a few google searches hmmmm
Well I wasn't the original purchaser of the diff I had problems with and they sorted me out free of charge.
I am 95% sure the warranty is on the diff itself not the person.
Thanks mate. Fingers crossed I don't have a leak for starters. But if I do, fingers crossed the warranty will still cover me.
Still the aggro of getting the diff out of the box and getting it to them, but I can cross that bridge when I get there.
No worries. Hope you get it sorted one way or the other.
Let us know how you get on.
What a PITA, hope it is/was just the seal. Make sure the box is upto temp to surly check for any leaks, did you put the undertray back on?
