Since the last update I've been busy wiring away and also busy at work and uni unfortunately so it's taken a lot longer than I'd planned to get to where the car is now.
The little bits that I've been managing to do some evenings have all come together today however after spending a good afternoon down with the car. Last week I wired up a permanent live to the fuse box on the dash pod, running a wire from the bulkhead connector.
I also made a new plate for the relay boxes to fit into (with the help of Pete's welding). Then bolted the boxes in and begun wiring...
I begun by creating an earth post on the front bulkhead to run earths to for the relays and eventually the main loom. Then I wired up the fuel pump through the relay, fusebox and switch... after much head scratching trying to get my head around it. Once again I've not fastened any of the wires down yet as will still need to take a lot of them out/tidy them up to finish spraying the inside so there was no point. Just needed to get the car running to begin cutting the loom again and other stuff.
While I was busy wiring away - Alex and Pete installed the filler cap and pipe so we could put some petrol in the tank to start the car, will be painted when the rest of the car is.
After I'd finished wiring the fuel pump up, I connected the fuel lines back up and tightened them all up. Then we had a go at starting the car for the first time in our ownership... a few months under a year later, we're proud to say it lives!! Even if it does sound like a motorbike with no exhaust or airbox attached
After celebrating quite a lot... I got back to being serious and took the slam panel off so I could drop the competition alloy Polo radiator we'd bought in the eBay 20% off sale not so long ago. Need to make brackets for this to mount it next and then get the coolant pipes connected back up and then the exhaust. This will allow us to then run the car without doing any harm so we can cut the wiring loom down again.
So along with that, we can also get on with wiring up the radiator fan and also some internal fans which will both need mounting. Plenty to keep busy on as usual! So happy with the progress today, feels like the car is finally coming together
Over the moon.
EDIT: Forgot to mention, we've ordered some wheels! New Team Dynamic Pro Race 1.2 in White, 15x7 ET35 :tongueout:
