Cracked trophy turini
Car  RS2'd Trophy
Hi there.
I have a Clio trophy and one of the tyres persistently kept going down over night! I had 2 new pilots. Unfotunatly this didn't solve it either!
The wheel has a perfectly straight crack with no dint or paint deformation on it so I can only assume it was a pothole! The crack spans from the edge of the inside rim to the bend into the barrel about 10mm long.
Does anyone know where I'll be able to get this repaired in Nottinghamshire?
James
Almost any wheel refurber will be able to weld the crack. Just ring some in your local area to see if they will fix it it for you.
