Quote: Originally posted by SilverRSC on 30 January 2004
Slightly modified to include Cliosport.
Dear sirs,
I am writing to you in query of a fault I have on my Renault Clio 172
The fault is as follows, under hard acceleration which causes wheel spin it would appear the engine bangs against the sub frame of the car and some cases has been known to knock the car out of gear. This as you can imagine is not a pleasant experience and when resulting in removal from gear quite dangerous.
As a member of Cliosport.net I have discussed this matter with a number of fellow Clio owners and it appears I am not alone. A number of people have sought dealership advice on this matter only to get a number of differing replies. These have included a problem with the engine mounts and the fact it was a characteristic of the car. [Referring to a 172] Although one Renault dealership (RSport) believes the problem can be rectified, however, the work required would not be covered by Renault warranty.
As a customer of Renault UK I find this unacceptable and would like your views on the matter. Any information regarding known remedies to this situation would be appreciated.
I look forward to your prompt reply.
Yours faithfully
Rsport arnt an offical dealership I belive there is a dealership called Rsport but its nothing to do with the RSport tunning company you are talking about.
Renault arnt doing to do anything I feel why because we have already bought 172 etc and when the 182/2005 Clio comes out they will say that a fix has been implemented in a new build car. Im a pesimist though
EDD
Quote: Originally posted by _KDF on 01 February 2004
Quote: Originally posted by marksmini on 31 January 2004
Hello everyone.
looks like im your only Renault tech member.
i work for Renault and have been there for 5 years, now i no extactly what you mean, i even have it on my 172 clio, mines a MK1 tho.
right hear i go.
if you have a mk2 clio 172 normal or a 172 cup, Renalut have just about 3 months ago, brought out a new tech note with ref to nocking noise.
now what we do which is under warrenty is to cut away a small section of the top sturt on both sides so the suspention is not nocking. sounds mad but we have found that this realy works, even the lads at work who have a mk2 clio 172 they have done this to theres and it has worked!
if you go in there and tell your dealer of this noise and u have been told abpout a note with ref the to suspention sturt this will realy help. i will even try abd get you the note number so you cab tell them.
sending a letter may sound a very good idea but i realy cant see them saying much other than we are very sorry bla bla bla..
but the nocking is very bad cos i want to put my foot down and you cant due to once the traction is gone the drive shaft sounds like it is trying to jump into the passanger seat lol
so mk2 clio 172 they have found a 90% cure
but mk1 clio (mine) im still looking but if i find out anything i will let you lot no.
far as i no the v6 clio dont have this problem, cos ive never come across this on the v6, touch wood lol
does that help at all??
also i would help more but 1 post evry 3 min takes far too long and a max of 20 aday! will take ages to help you all. unless this is lifted..
also how do i get a pic up as a avatra? i cant work it out, cheers
mark
There are a couple of others on here that work for Renualt. There is another fix for mk 2 Clios that stops rumbling in the suspension which involes modifiying the suspension top mounts.
Perhaps if you could get the tech number we could verify it with the other Renault people.
ps. only memebers can have an avatar (the little image next to your name)
