Changed the bootlid at last
Cleaned areas and routed wiring etc
Old number plate snapped from an over kill of tape
Ordered a new one, but here it is before I cleaned and polished it up
Next..
The Cup decided to ask santa for a clutch...
Mean't I could fit my speedo drive box, Millers Fully Synth and an OE non-slipping clutch!
Tool's at the ready here goes..
This job was a complete nightmare working on the floor, barely above freezing temps, on axel stands, and on your own bench pressing it all!
Note the transport in the interim ...
What I found :dead:
Pressure plate.. bolt stuck in place and cracked casing
Other side completely broken off (piece was still bolted in the flywheel)
Gearbox casing scored but luckily not damaged at all
New Valeo Clutch, bearing, pressure plate, grease and alignment tool and plate
Boom! Aligned a beaut, box slide on first time on my own
Sump plug washer replaced and silky new oil going in
A huge amount more happened in this clutch / gearbox process, but very happy to know it's done correctly.
If I had a crane with me, I would of been one mount, or a few bolts away from pulling the whole engine out itself.
Anyway finally mean't I could clear this code!
The car was pretty lagged with all the work so a Karcher / Meguiars clean down
Gave the misses 225 a once over, however I only dried the Clio
Took it to the end of the street and back, speedo working, auto lock kicked in, and things were feeling good apart from the camber was miles out.
So went to pull the wheels off but the passenger side bolts decided to ...
Fix one, gain another I guess!
Will be sat around until the replacement hub arrives to save me faffing around with removing the studs
Sigh !
Next..
What I found :dead:
Sigh !
