Sunglasses_Ron
ClioSport Admin
Great work JP :up:
No dude! We've had it running, and I'm just waiting on when Alex is free to finish the last bits on the loom, get it painted, and finish the last few bits.Have you driven it yet?
It's all thanks to @AlexW ! The lad knows his way around them
I don't think they've tackled that side yet. I would grind them off as said!How coMeyou didn't drill the spot welds out on the unused brackets?
HahaWhich brackets?
To be honest I'm not going to be chasing ounces of weight when I'm built like the stay puff marshmallow man.
Haha!Looking good.
I'm afraid my only solution to the sidelight problem would be a lump hammer. Let us know how you get on.
Well. What started off as a really good day, has gone right down the shitter....
Made good progress with more jobs on the car:
Protective wrap on the rollcage applied, dash mounts added.
EPAS switch put in position on dash.
Exhaust mount fitted.
Grip tape applied to drivers footwell
Seat is in place too!
View attachment 192027 View attachment 192028
Then this afternoon it all went Pete tong.
I was busy fitting the new headlight when there were some sparks at the battery (little bro spotted it). We assume it was a socket bar had fallen and hit the battery terminals (somehow?!), after I'd left it lodged in the rear arch area.
So now the lights appear to be completely messed up.
Sidelights are now working.
However, low beam doesn't work on the passenger side (new headlight).
High beam doesn't work at all. There's no click at the UCH either.
Also, the tail lights work but there's no brake lights or rear indicators.
Continued on this evening with some other work it have come inside in a proper huff.
Guess I'll be cancelling the MOT in the morning then!
I would check the earth's under the dash incase it's loose and it's been knocked.So at end of play tonight, electrical problems are as follows...
No high beam
No brake lights
No working front wipers
No needle movement on dash (I.e. When revving)
No horn
Done a dash test (pressing end of stalk and turning on ignition. Lights ondash come on, and all needles move during test.
I've pulled all the fuses in the engine bay and interior fuse boxes. No broken fuses.
I've reseated all the relays in the uch (the ones at the back).
Earths have been checked in boot (need to check under dash, but nothing has changed since the other night when the lights all worked).
Also during the dash test I've got a couple of codes: t - - h
View attachment 192120 View attachment 192121 View attachment 192122
Will take a butchers.Pop the UCH off , see if there's any circuit board fried. I did this on my old Dci... accidentally hit The alternator poll doing a filter change , dash wouldn't work, lights intermintant and horn dead.
He's going to see when he's free. I'm desperate to get it done this week though.Ah bugger. You may have to start checking looms everywhere,
UCH
usually take the brunt of it when something shorts out and does this.
Need MR white to have a look :wink:
Well I can feel which relay clicks when the sidelights and low beam are activated, but couldn't when the high beam was on.Relays for the headlights are in that row next to the UCH. ( the set that goes on The side )
